Results 11 to 20 of 25
Thread: Inline fuses, tell me about them
  1. #11
    Variable Bitrate Saab9-5's Avatar
    Mar 2005
    Ponta Delgada, Azores
    That is correct.
  2. #12
    Feb 2005
    Quote Originally Posted by CavityCr33p
    Awesome! Thanks for all the help guys.
    http://www.radioshack.com/product.as...ct_id=270-1238
    So do you just use two leads? one from the battery and one to the amp/inverter? What im trying to say, as by looking at that picture, it looks like it splices 2 leads together, with a fuse in the middle, am I correct on this?
    They are called "in-line" fuses. Therefore they go inline. Imagine a hot wire going from your device to the battery. Cut it. You now have to loose ends. They attach to each end of the in-line fuse. Direction doesnt matter. You still have to ground the device. Do not connect the grond and the hot together via the inline fuse. That will result in a blown fuse. I recomend this for you.
    http://www.radioshack.com/product.as...ct%5Fid=28-288
    or this one http://www.radioshack.com/product.as...ct%5Fid=28-280
    I think we should try to get these available at the mp3car.com store. They are very useful training tools. They are made for kids but believe me, we could all learn something from them.
  3. #13
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    You know whats sad, I went to school for all of this (graduate and certified PC tech, we took AC/DC, transistors, Analog, Digital, all that). I kinda skipped past all of that crap, since I was there just to get my certifications (Cisco, A+, etc)
    I am a full time computer tech, I watch over 25 servers, but don't know about all of this...sad isnt it?
    2000 Sunfire build 100%, or is it ever really 100%?
  4. #14
    Mar 2005
    Now all of that crap is coming back to haunt you. A friend of mine went to TESST Electronics school, made honor roll every quarter, aced all of his tests. But ask him about basic parallel resistor networks or the function of a capacitor and he has to go back to his notebooks to look it up. Funny, he too is a systems administrator monitoring a company's servers and WAN. I wonder if that's coincidence or a pattern?
  5. #15
    Variable Bitrate rubicon's Avatar
    Feb 2005
    $240 worth of puddin'
    Quote Originally Posted by Saab9-5
    Good point. You don't want to run something like 24 gauge wire with a 30 amp fuse to your amp, only to have the wire overheat and ignite your carpeting!
    I'd have mentioned that, but I thought it was obvious. Then again, the original poster was asking what a fuse was... Maybe not so obvious.
  6. #16
    Feb 2005
    Quote Originally Posted by slappy
    (snip electronics kit url)
    or this one
    I think those kits are a bit too in-depth for what the original post was about. A simple "a fuse is almost exactly like the circuit breaker in your house" kind of answer would have sufficed (as would a search...)
    True, but way overkill. I seriously doubt that anyone on this board would buy one, because we all either
    1. (mostly) know what we're doing already, or
    2. find it easier to start a topic titled, "What is electricity, and do I need it for my carputer?"
  7. #17
    Feb 2005
    Its a pattern. When someone learns a fact without understanding the reasoning behind it, then other facts relating to said fact can be a mystery.
    Would one expect an electrician to know anything about R/C circuits? Or an "IT professional" (read: retarded computer monkey) to know how to write a piece of software? Sure, the occasional overachiever might, but in general, no, one wouldn't.
    All of the A+ and Cisco and (insert flavour of the week here) certifications (MS in particular) are bunk - get yourself a CS or EE degree if you want to know what you're doing. Everything else is just a gold star for paying too much for what amounts to freely available information.
  8. #18
    Constant Bitrate ChaCha's Avatar
    Nov 2004
    Los Angeles
    I'm not sure about this info as I'm a total noob and have yet to actually get my project finished and installed, but I read somewhere that you should place the fuse as close to the battery as possible, no more than 18" from the battery.
  9. #19
    Variable Bitrate UM_Fan's Avatar
    Feb 2005
    Miami, Florida. 305
    I'm currently CCNP & CCDP, we don't see "parallel resistor networks or the function of a capacitor" as a network admin . That should be done at the A+ course.
  10. #20
    Mar 2005
    Quote Originally Posted by UM_Fan
    But the point is he went to a school specifically to learn those things.
    You can't climb the ladder of knowledge, forgetting the rungs that you were previously on.
  1. melted fuses
    By corsamel in forum General Hardware Discussion
    Last Post: 03-26-2005, 04:37 PM
  2. LINITX - Basic fuses question
    By OriginalNick2 in forum LCD/Display
    Last Post: 01-22-2005, 07:40 AM
  3. Replies: 6
    Last Post: 07-14-2004, 08:07 PM
  4. Arrgghh! Fuses!
    By DJKhan85 in forum General Hardware Discussion
    Last Post: 06-16-2004, 10:11 AM
  5. still blowing fuses
    By ToxicPoison in forum General Hardware Discussion
    Last Post: 02-12-2001, 10:45 AM
