Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Inline fuses, tell me about them
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    Getting close to time for the install, and I have read several things here (and other places) about using a Inline fuse.
    What exactley is this? I hear that its supposed to prevent your car catching on fire in case of a voltage spike.
    I was reading on amp hookups, and how they are used in hooking up amps, but Ive read here that they are used on hooking up inverters also (what I will be using)
    Do I need two if I am running a amp and a inverter?
    2000 Sunfire build 100%, or is it ever really 100%?
    Constant Bitrate HostileJava's Avatar
    Mar 2005
    Northampton, PA
    They are just fuses that are run inline with the power wire. They preven whatever device or devices you are running from drawing to much current or will prevent the wire from drawing to much current if it shorts against the frame somewhere. You want to use one slightly larger then what you think your current draw is giong to be.
    Jun 2003
    Arkansas
    Where can I get them and how do they install? Do you connect one end of the wire on one side and the other on the other side?
    Dec 2004
    Wichita Falls, Texas
    Best place to figure that out is look @ the fuse contained in whatever it is you are running.
    My opus uses a 15 fuse. The amp uses a 25 fuse (btw im a paranoid freak you dont really need all teh fuses i used)
    So as soon as the 12v line leaves my battery I have a 40 fuse which goes to the distro block which I have put 30 fuses on, one goes to the amp, the other side goes down into another 15 fuse before it hits the Opus.
    In my experience adding up the fuse number on your devices on that line will tell you what number inline fuse you should be using.
    I don't know if that is the right logic or not, but it works for me.
    Variable Bitrate rubicon's Avatar
    Feb 2005
    $240 worth of puddin'
    Quote Originally Posted by CavityCr33p
    You can get inline fuse holders (and fuses) at Radio Shack, though you can get fancy-schmancy ones at car audio places, but that's overkill. Blade or glass doesn't matter - its personal preference. Connect it inline on the +12v line between the bat'try and the equipment, somewhere convenient.
    Make sure you don't get "slow-blow" fuses (for this application), and get a fuse rating just a bit higher than what your equipment will be using (as another poster stated).
    NB. Fuses are meant to protect
    1. your equipment
    2. your *** (fire bad! hot water burn baby!)
    in the event of a short-circuit.
    Also - if, for example, your equipment should be drawing a total of 40 amps (max), and a 40 amp fuse keeps blowing, don't use a higher-amp rated fuse instead - the fuse is blowing for a reason.
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    use the lowest rated fuse possible for the equipment...but you have to make sure the wire itself is rated for higher than the amperage of the fuse.
    rebuilding carpc... kinda..
    Feb 2005
    Quote Originally Posted by koolaidkitten
    That's about right. There's no special magic in this instance, not like determining the total capacitance of multiple capacitors connected in series vs. parallel.
    Mar 2005
    Northampton, PA
    Also someone stated to mount it some place convenient. You can do this, but the recommended spot is as close to the battery as possible. That way if the line shorts it's less likely that the short will occur between the battery and the fuse. If the short does occur between the battery and the fuse, the fuse isn't going to help you.
    Variable Bitrate Saab9-5's Avatar
    Mar 2005
    Ponta Delgada, Azores
    Quote Originally Posted by fantomas
    Good point. You don't want to run something like 24 gauge wire with a 30 amp fuse to your amp, only to have the wire overheat and ignite your carpeting!
    Jun 2003
    Arkansas
    Awesome! Thanks for all the help guys.
    http://www.radioshack.com/product.as...ct_id=270-1238
    So do you just use two leads? one from the battery and one to the amp/inverter? What im trying to say, as by looking at that picture, it looks like it splices 2 leads together, with a fuse in the middle, am I correct on this?
  1. melted fuses
    By corsamel in forum General Hardware Discussion
    Last Post: 03-26-2005, 03:37 PM
  2. LINITX - Basic fuses question
    By OriginalNick2 in forum LCD/Display
    Last Post: 01-22-2005, 06:40 AM
  3. Replies: 6
    Last Post: 07-14-2004, 07:07 PM
  4. Arrgghh! Fuses!
    By DJKhan85 in forum General Hardware Discussion
    Last Post: 06-16-2004, 09:11 AM
  5. still blowing fuses
    By ToxicPoison in forum General Hardware Discussion
    Last Post: 02-12-2001, 09:45 AM
