Results 1 to 10 of 13
Thread: Powering TFT
    Mar 2005
    Powering TFT
    Hi guys! I've been lurking around the forums for awhile and finally decided to join. I havent built my system yet and just started doing up a diagram with all the parts and how I'am going to wire it. But I've come into a problem.
    The monitor that I'll be using is the TM-700TS and I'll be using the Opus 12Volt DC-DC 150W ATX Power Supply. My question is how do I power the TFT through the PSU if all the connections are taken. The only thing I can think of is use the 12V connection that is used for the hardrive but that will already be used up right?
    Thanks Matthew Shaw
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    Quote Originally Posted by matthewshaw
    Thanks Matthew Shaw
    Splice the cable.
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    get a 1 to 2 adapter. Or splice the cable.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    You're using the floppy connector?
    Fabricator
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    what you dont have a floppy drive in your car? for those one hit low bitrate wonders?
    肚子笑痛了
    S60 Install
    Mar 2005
    Quote Originally Posted by Altimat
    Good point!! Thanks man
    Mar 2005
    Just to double check. So the T-View TFT can use an 8pin connector to power it? And if not how do I power it?
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Cut up a molex splitter and add a connectoer for the display. This allows you to disconnect the LCD if you need to.
    One like this
    http://www.cyberguys.com/templates/s...search=&child=
    this allows you to avoid cutting the PS and lets you swap parts if needed
    TruckinMP3
    Read the FAQ!
    Mar 2005
    Thanks for the link man. Just wondering if theres anyone out there with the same monitor, how do you power it? To clarify again I dont yet have mine.
    Tainted Love Cris's Avatar
    Romania
    You can easily mod the cables. You can get the wire out of the connector with a little needle and a little patience. That's what I did so I woudn't have useles cables in the case, and for the looks. So far, from my PSU I have powered: 3 monitors, slim DVD drive, neons and a USB hub.
    To power the screen you need a 12V line and a GND line from the PSU. Then you connect these to the "+" and "-" from the screen cables through a connector.
  1. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 03:19 PM
  2. Difference between STN and TFT screen?
    By noodles in forum LCD/Display
    Last Post: 10-23-2003, 05:32 PM
  3. Replies: 2
    Last Post: 06-18-2002, 04:31 PM
  4. Probs with picture size on TFT
    By felix99 in forum LCD/Display
    Last Post: 06-17-2002, 04:56 AM
  5. Powering a 4" tft?
    By ToxicPoison in forum General Hardware Discussion
    Last Post: 02-09-2001, 12:02 PM
