Results 1 to 9 of 9
Thread: Splicing Audio Jack Wires
    Jan 2005
    Right now I have an audio jack that I plug either into my mp3 player or my laptop.
    Can I splice the wires into two audio jacks and have one plugged into the mp3 player and the other plugged into the laptop?
    Will I be able to play music from one jack while the other is plugged in?
    Will I be able to play music from both at the same time?
    Newbie SVTRanger's Avatar
    Mar 2005
    Oak Harbor, Wa
    I wouldn't splice it, you can go to Radio Hack and get a y-cable. As far a having them both plugged in at the same time, it depends on the devices, some will work that way and some won't, that one is trial and error. I wouldn't play both at the same time though, may or may not cause bad things to happen.
    Install { 50% } Complete for now.
    But stable and running happily
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    You shouldn't play both at the same time, since the two will fight each other, potentially damaging them. You may want to consider a very basic mixer circuit http://www.hut.fi/Misc/Electronics/c...s/linesum.html.
    Jan 2005
    SVTRanger - the link mushin gave says a y-adapter is not the way to go.
    Mushin - in the diagram, it's hard to see which end is ground, and which is v+ etc.
    Variable Bitrate Saab9-5's Avatar
    Mar 2005
    Ponta Delgada, Azores
    phita23 - In those diagrams, where it says (shields), those are the grounds.
    Jan 2005
    Oh man, I still don't see it. Can someone sketch up a simple paint diagram?
    Variable Bitrate fromplanetbob's Avatar
    Jan 2005
    Quote Originally Posted by phita23
    Just put a 10k ohm resister in series with the L and R audio, then join the L and R channel from multiple sources. The grounds can all be connected. If you can't handle that, then you really should have someone build something for you.
    Jan 2005
    Got it. I guess reading the description would have helped.
    Why do the resistors work/do the job?
    Jan 2005
    My wife would tell you that instructions have pictures for men and words for the ladies. The webpage goes over it, read it all.
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. Replies: 1
    Last Post: 03-20-2005, 09:41 AM
  3. Splicing inverter wires
    By du3ce in forum Power Supplies
    Last Post: 03-16-2005, 11:18 AM
  4. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  5. mobo audio jack sloppy
    By cybermob2 in forum General Hardware Discussion
    Last Post: 05-12-2004, 09:27 PM
