Kyle,
You may want to go re-read a bit. Take a good look at the definition of "last". The capacitor voltage decays at an exponential rate. You need to define "last" as the point in time at which the voltage drops below the acceptable operating point for whatever is connected to it. The standard "RC time constant" curve defines that time at which the voltage reaches 63.2 percent of it's final value. If you are discharging from +12V, the RC time constant is the time at which the voltage decays to 4.416 volts (12 * (1-63.2)). There are very few DC-DC converters/inverters that will continue to operate at 4.4 volts...
HERE's a pretty good explanation.
Good start...keep reading...![]()
LinkBack URL
About LinkBacks
