Results 1 to 9 of 9
Thread: how to make xbox turn on when car is on?
    Apr 2005
    how do you go about making ur xbox turn on when your car is started?... i am using a power inverter and my xbox is in the backseat/trunk.
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Wire relay or ITPS to Xbox power switch?
    Apr 2005
    you could do what some have done with computers.... take apart the power button and mount it near the dash. You would just have to extend the wiring....
    Or...
    Try hardwiring the wires that the button control into your accessory power wire.
    I would go with the first idea becuase you wouldn't want the XBOX on all the time...inverters can get hot ya know..
    Elsewhere
    In theory, you could get an adapter that allows any ATX power supply to be used with an XBox, then use an Opus 150w PSU, which powers on with the ignition.
    It really depends on the power draw of the XBox. I'm not certain of that.
    Someone has suggested that here, but I don't recall seeing the results...
    How about the Wiki?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by DarquePervert
    DP, what do you think about an M1 with it?
    It is only a P3 733 (i think), small mobo and not much else but a hdd and some grpahics and sound hardware.
    Should work to be honest.
    Jan 2005
    Have already put an M1 into an xbox and it works!
    Use the , I cant be arsed to find it!
    It works well and of course you can use the M1 ignition wire to trun the xbox on and it all fits nicely inside!
    Apr 2005
    can i put a piece of tape on the xbox power button so its always pressed? lol
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    Nope. Try it. If I'm not mistaken it will shut down automatically, after a few moments.
    Actually modifying the power switch isn't that hard, and if you know how to use a relay it's easy. If you don't: look. It's basically a switch. However, rather than a finger pushing abutton or flipping it it works on a magnet. This elts you "flip the switchy" with a electric current rather than say... your finger.
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    kumanan, its a momentary switch, not a toggle. The Xbox receives the impulse when you hit the button and uses logic circuits to do the rest. Holding it down won't do anything.
  1. Replies: 1
    Last Post: 01-19-2005, 03:43 PM
  2. Real Time Car tracking now working!
    By Magpie in forum GPS
    Last Post: 10-27-2004, 04:08 AM
  3. Replies: 18
    Last Post: 06-18-2004, 09:11 AM
  4. off the wall ideas
    By bubbrubb in forum General Hardware Discussion
    Last Post: 04-20-2004, 02:19 AM
  5. Car Stereo Installation Video's for Sale
    By johnram in forum Classified Archive
    Last Post: 09-05-2002, 10:27 PM
