The screen
I have a screen with the normal video out connector (rca type) is there anyway of converting to a vga connector?
Would the quality be better? Than if i ran this with an rca to s-video cable?
As i would want to use as a dvd, winamp and maybe gps screen?
PLEASE HELP NOOB!!
The screen
hacing details on the screen will help: who makes it, what model is it... link to specs.
TruckinMP3
Read the FAQ!
Its a pioneer screen, but was from factory so dont now which model!
Is it possible to split the wire in a vga connection? OR would s-vide be better?
Will quality be shocking? Screen is £70, so $125
why are you double posting the same question?![]()
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Use the S-VGA output. Change it to RCA and plug it into the monitor. VGA is not compatible with the RCA video (NTSC) signal.
Before you decide to use this as your main car computer interface, hook it up to a computer with an SVGA or RCA output and see if you like it. Expect it to be fuzzy and difficult to read the smaller text (anything under about 16 point).
Want to:
Thanks, would it really be that fuzzy being only 6.5" wide?
Will it be alrite for winamp, dvd etc, just not gps?
You should be fine with dvd, you may have some problems with reading the file names in winamp. Same problem with reading street names with gps.
Installed
Any way of improving it?
Would it be any better if it was just straight s-video and no rca to s-video?
I don't know how much clearer the text would be with just s-video, I wouldn't think it would be much of an improvement. If you really want to be able to read text I would suggest you buy a lcd with vga and sell your current lcd on ebay.
Installed
