It should work with the latest version of Frodo Player....
or you can try frodosatradioX....
In my opinion the LS2.0 skin works best for XM......and frodoplayer.
Make sure you set the right com port in your Frodoplayer settings.
If you use Frodosatradio, make sure you set the right port in their as well.
Also, make sure you activate your XMdirect unless you like just the preview station....
But you should get something from the preview station at least if all is hooked up, and running correctly.
Good Luck!
LinkBack URL
About LinkBacks
