Umm...let's see...if I have properly deciphered your message, the PC powers on when you set the key to accessory or on, but shuts off when you crank the engine. Sounds like you need larger gauge wire from the battery to the power supply.
epia800 mobo
m1-atx
Morex Cubid 2699V
120gig hd
slim dvd
512 133 ram
Lilliput 8" touch srceen
d-link usb fm radio
Sound Blaster Audigy 2 ZS
3usb 18card reader hub
i used the wires from my old stereo 12 and ing
epia800 mobo
m1-atx
Morex Cubid 2699V
120gig hd
slim dvd
512 133 ram
d-link usb fm radio
"12 and ing"? Huh? Can you be a bit more descriptive?
Stock stereo wires are going to be a bit small for this power supply, for +12V and ground you REALLY want to run larger-gauge wire (around 10ga) to the battery.
sorry,12 volt and 12volt ignition from old truck stereo
epia800 mobo
m1-atx
Morex Cubid 2699V
120gig hd
slim dvd
512 133 ram
d-link usb fm radio
Go ahead and use the ignition lead from the old stereo, but definitely get larger-gauge power cables run to the battery. There's likely too much voltage drop on the smaller gauge stock cables when you crank the engine, that's why the power supply is cutting out.
cheers for that,just 1 more ?,getting interferance on monitor and through speakers when truck is running.
epia800 mobo
m1-atx
Morex Cubid 2699V
120gig hd
slim dvd
512 133 ram
d-link usb fm radio
: Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
: Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
: BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
lead from battery now and working fine
epia800 mobo
m1-atx
Morex Cubid 2699V
120gig hd
slim dvd
512 133 ram
d-link usb fm radio
good to hear.
1990 Jeep Cherokee
2000 VW Golf TDI 4dr
2005 VW GTI MKIV - SOLD
