Results 1 to 10 of 15
Thread: k6 500 mHz enough?
    Newbie screwmesa's Avatar
    Apr 2005
    Gilbert, AZ
    k6 500 mHz enough?
    Hi all,
    Will a k6 500 mHz be enough to play mp3s and dvds?
    I'm more worried about the dvds, but it will have 512 mb of ram.
    Thanks.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    hmmm not sure. a P3 450 will paly DVDs ok but i dunno about old AMD chips.
    if DVD is your only issue get a graphics card with DVD decode (any one int he last 4 years or so) or a hollywood plus card from ebay.
    edit: make that over 5 or maybe 6 years infact! Damn it's 2005 already!
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    I had a AMD K6-2 400MHZ - it had problems with Divx
    I upgraded to a k6-3 450mhz and it played but skiped a lot
    As far as DVD, a good AGP or PCI video card will play them fine
    as most new-er Video cards have the decoder hardware on them
    I would try to get a faster system - but it may work just fine
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    This would be a case were i'd actually recommend a VIA system. Its most likely going to be faster.
    Apr 2005
    A K6-2 500 should have enough power for software DVD playback. I've seen software DVD playback run okay on a 400MHz Celeron so as long as your DVD software is relatively well optimized it should work.
    You might actually want to go with an older video card (particularly since most of the really new cards won't work in an AGP 2X bus which is presumably what your K6-2 has) as the newer cards assume you have more CPU cycles to burn on things like DVDs so they can offload more of the decoding to the CPU. The ATI Rage Fury has a pretty good DVD decoder. I was able to play DVDs with only a 350MHz K6-2 using one of those cards. Should be really cheap now.
    Aug 2002
    Eau Claire, Wi
    older amds have always seemed to do poorly on multimedia playbak in my experience. where a slower intel celeron would play it just fine. I have a k6-2 450, 256 mb ram in the basement and it will not play divx or dvd smoothly in software.
    System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
    Progress: Installation: 90% Dash fabrication: 80%
    Parts Needed: USB GPS
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by meyer64
    Ditto
    Newbie Gazza's Avatar
    Feb 2005
    Best to try it. I am running a P3 450mhz with 256 meg ram using the on-board video and it plays DVD's just fine using PowerDVD.
    Cheers.
    P3 900MHZ 256meg, 160 gig 3.5, Lilliput 7 Touch screen, GPS (not working..yet), 3 million wires. 3 amps,
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Gazza
    Cheers.
    Yeh, but you've got a P3. The P3 is much better than the AMD. Really. The AMD chips were slow, until they got to the athlons.
    Apr 2005
    Gilbert, AZ
    Thanks mask of destiny I'll try to pick up one of those cards. hard drive's in the mail, waiting to get it then I'll try the onboard and see how horrible it is.
  1. FS: Celeron 500 w/ Mainboard, Make Offer
    By surfer6262 in forum Classified Archive
    Last Post: 07-03-2004, 12:32 AM
  2. FS: Celeron 500 and Mobo Make an Offer!!
    Last Post: 03-31-2003, 06:08 PM
  3. FS: Celeron 500 and Mobo
    Last Post: 03-27-2003, 08:49 AM
  4. FS: Celeron 500, Mobo, Ram $40
    Last Post: 03-27-2003, 08:34 AM
  5. 500 mhz computer for sale! UPGRADES!
    By thaladyzman in forum Classified Archive
    Last Post: 01-12-2003, 08:45 PM
