Results 1 to 10 of 12
Thread: Ribbon Cable
    Low Bitrate fabiolover2002's Avatar
    Jun 2004
    Ribbon Cable
    Hi I have chopped up my lilliput and installed it into my double din slot. However I would like to place the buttons about 4 feet away from the screen. Is there anyway to extend the little ribbon cable to the little board with the buttons? I am sorry but I am a newb and I'm guessing that you can just solder the cable to individual wires, so i just want a little guidence before I mess anything up. Thanks!
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    or just buy another ribbon cable from armen and do a really good job of taping the contacts together. We're in the newbie forum here :P
    Jun 2004
    The second idea sounds good to me. I'm going to look for one right now. Thanks a lot for the help .
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    The second idea will not work as well as the first - it will probably come apart with time. the first idea seems like more work - but it's not.
    Chop that cable right in the middle. Now heat the ends up, so the plastic melts away. youre left with a few wire strands sticking out - just solder them up to a longer length of wire, between the other end. If you mess anything up you only spent a few bucks, and you can just order a new cable from armen anyways.
    Mar 2005
    Dr. H:
    Thanks, I'm always one for the cheap route.
    Let's say that Armen's cables are $20.
    Radioshack sells a soddering iron, which willl last a long time for $15, and dollarland sells wire for $1. Well, you could spend $4 less, and come out of this withg some spare wire and a soddering iron (plus some basic soddering skills).
    Woodbridge, VA
    Blog Entries
    32
    ok, but armens cables are 6 dollars as i recall.....
    Jun 2004
    I have no experence soldering, but I may be able to get help from one of the TV aides at school. Would you recommend that route?
    Mar 2005
    I'm a TV aide at school, and frankly those guys knwo nothing. You can try - but you should try to learn it's good practice, honest.
    @Sonic: $6? Not bad. However still a bad diea for anyhting toher than testing
    Constant Bitrate John_Duh's Avatar
    Feb 2005
    Belgium
    if you know what the hot end of a soldering iron, and solder is you'll be fine. Soldering isn't an art when it comes to getting two wires to stick to each-other ... just go for it and get the practice. It will come in handy later on :-)
    '02 Toyota Celica TS
    Carputer progress : [#######---]
    Currently working on : software ...
    Parts : IBM thinkpad X60 wired up in the booth (T7200 - 1.5Gb Ram - 320GB HD)
    Parts needed: USB wifi dongle (with external antenna)
    Jun 2004
    Can anyone give me a step by step guide on how to do this?
  1. Lilliput 8" ribbon cables?
    By therussman2002 in forum General Hardware Discussion
    Last Post: 12-24-2004, 10:17 AM
  2. Lilliput and ribbon cable problems
    By Udonboy in forum LCD/Display
    Last Post: 11-08-2004, 08:24 PM
  3. Replies: 10
    Last Post: 08-12-2004, 05:45 PM
  4. WTB: Lilliput ribbon cable clips
    By eatyummypuppies in forum Classified Archive
    Last Post: 07-24-2004, 03:46 AM
  5. RE: New Lilliput - Ribbon Cable Problems
    By 047025n in forum LCD/Display
    Last Post: 06-30-2004, 06:21 PM
