Results 1 to 10 of 10
Thread: mac harddrive in p3?
    Mar 2005
    Middle of Kansas
    can i put a mac harddrive on a p3 and if so how do i go about deleting all the exsisting files.
    Constant Bitrate Willy-Mach1's Avatar
    Mar 2005
    Laurel, Maryland
    You should be able to.... what makes a mac hard drive a mac hard drive is the file system.....you just need to format it to whatever file system you are using (NTFS, FAT32, etc.). If you are installing windows, the windows installation should give you the option to format the drive, just make sure that you do a full format and NOT a quick format. Hope this helps!!
    Progress: |##########| 99.99%
    - Tweaking and enjoying!!!! Never really done.....
    -= MachPuter Project =-
    -= MachPuter Project Worklog=-
    Mar 2005
    Middle of Kansas
    does a icon come up and ask or do you have to search to do it and what about everything else RAM, Motherboard, floppy drive, etc. thanks for the info
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    you have to format the drive to fat32 or ntfs to use the drive in windows. whne you format iit will wipe all data.
    EDIT: Make sure the drive appears in your bios and then when in windows if it does not appear in 'my computer' you need to go to disk managment and format it there. (right click on 'my computer' and click manage)
    Mar 2004
    Bristol
    OR if you installing windows on the drive just use the full disk format option.
    as for the mobo - well the MAC doesnt use P3 CPUS so no! and the memory - maybe but i doubt it. Would have to be the same ram as your p3 mobo takes (normally PC133 SDRAM)
    Mar 2005
    Laurel, Maryland
    Are you installing this hard drive as an additional drive on a windows machine or do you want to install windows on it from scratch? As for the RAM I am not completely sure but I think you can use it. The motherboard does not work with P3s or any Pentiums....floppy drive, the same as ram.
    Mar 2005
    Middle of Kansas
    thanks for answering my questions and my school is letting me have a p3 without the harddrive and are selling some macs for $10 so i figured make i can just take the harddrive out of the mac and put it i the p3. as for ther other stuff in the mac i justed wanted to know what i could do with it. if i could use them or just toss them
    Mar 2005
    Laurel, Maryland
    Since you are installing Windows (i suppose) from scratch, just follow the instructions in the installation and it will walk you through formatting the hard drive, just remember, do a full format NOT a quick format. As for the mac hardware, I would test the RAM to see if it works with your setup, the rest I would toss (for $10 they can't be giving you much).
    Mar 2004
    Bristol
    you could always just use the MAC
    (i can't believe i said that - now i feel dirty)
    Mar 2005
    Laurel, Maryland
    @Scouse Monkey
    You should feel dirty! Unless it is kinky dirty, in which case we really didn't need to know! oooohhh....nasty mental!!!!!!!!
  1. Mac mini in dash questions.
    By dfluxnet in forum MacCar
    Last Post: 10-03-2006, 03:02 AM
  2. USB harddrive disappeared
    By blak3r in forum General MP3Car Discussion
    Last Post: 04-19-2005, 03:56 AM
  3. Replies: 67
    Last Post: 02-28-2005, 04:25 PM
  4. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 12:25 PM
  5. Replies: 2
    Last Post: 09-08-2004, 06:07 PM
