Results 1 to 9 of 9
Thread: Attn Laguna Owners - passing wire through bulkhead
    Apr 2005
    Gloucestershire
    Hi,
    This is my first post after months of looking. I have a pc in my car powered by an inverter. Its purely for mp3s and uses a Matrix Orbital Lcd to display playlist and track information. Playlist selection and track changes are done using the steering column remote control. I am trying to install it so everything is hidden. Currently, the inverter is powered by the 12v accessory socket. I want to wire the inverter to the battery but can't figure how to pass a wire through the bulkhead. I can see where all the cabling passes through behind the glovebox, but can't get another wire through - any suggestions from those who have done this would be appreciated.
    OddJobBob
    Raw Wave
    Jun 2004
    On the beach
    273Below may be able to help, although not sure if he is on here or the UK forums - www.digital-car.co.uk, he is running a Laguna and a CarPC, from memory, a very tidy install.
    Failing that, I couldn't find a way through my bulkhead so I took a drill to it and put a rubber grommit around the cable, works perfectly.
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    Odd, I am just curious on how did you connect your steering wheel remote controls.
    Apr 2005
    Gloucestershire
    The matrix orbital LCD has a keypad input based on a 5 x 5 matrix (5 rows and 5 columns) = up to 25 keys. I just worked out what switch on the steering column did what and linked that to the LCD. The LCD then sends an output based on a character eg "C" to the serial port and my program detects that.
    Jun 2004
    The North, Manchester
    nice! wanna share?
    Raw Wave
    Jun 2004
    On the beach
    I have done something similar but using the PS2 Controller from an old keyboard
    Mar 2005
    Czech republic
    Thats my plan. Got it ready, as soon as I finish some internal cables and my ALPS encoder arrives, its next.
    Apr 2005
    Gloucestershire
    I have a blaupunkt stereo which has a 10 pin iso remote control connector. I have a wiring diagram at home and will dig it out later. Very simple. The only problem was the rotary switch. It seems to have three positions but the contacts stay closed when each position is engaged. No good for me which only left me with 4 switches. By the way, has anyone worked out how to activate the "aux" input on a stock blaupunkt stereo. The manual says it has a CD changer option but I can't work out how to wire it (no obvious input on HU - must plug through the remote or something) or to activate the Aux. Anyone know.
    Mar 2005
    Czech republic
    try www.2connect.com - they seem to have AUX adaptors for stock radios.
  1. ATTN: Jeep Wrangler owners
    By veedubya in forum General MP3Car Discussion
    Last Post: 03-30-2006, 07:49 PM
  2. ATTN: FV24 owners: How to wire a microphone
    By Alives in forum General Hardware Discussion
    Last Post: 03-25-2006, 04:48 PM
  3. ATTN: Morex/Cubid/Casetronics 2699r Owners!!!!
    By sq_geek in forum General Hardware Discussion
    Last Post: 12-06-2004, 09:43 PM
  4. Attn: 15' foot 80 wire IDE works. Paid 16 buks. -DVD-ROM (Say Yes!)
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 02-14-2002, 05:05 PM
  5. ATTN: Datalux LCD owners...
    By SuperMatty in forum LCD/Display
    Last Post: 01-22-2002, 07:20 PM
