Results 1 to 7 of 7
Thread: installing XP to a clean drive
    Apr 2005
    Just got a blank laptop drive and thought I would install and set everything up on my Desktop before I attatch it to my M1000 MB. Now I put the Bios to boot from the CD rom first and I put in the Windows CD but it keeps saying "Missing Operationg System" Anyone know why Windows Disk isn't starting up? Am I doing something wrong?
    Newbie krustydawg's Avatar
    Apr 2005
    Do you really want to do that. If you do you will install all the drivers and stuff for the wrong motherboard, video and sound
    But if you still want to make sure you go into BIOS and boot from CD is selected before C: drive
    krustydawg
    Carputer Project: 95% Complete!!
    VIA EPIA MII 10000 motherboard | Morex Cubid 3688 Mini-ITX Case | 80Gb 2.5" Seagate Hard Drive | Kingston 512Mb PC2100 DDR Ram | Mini-PS2 USB Keyboard | Microsoft Windows XP SP2 | Lilliput 7" Touchscreen | Rikaline 6010
    Newbie chapstick's Avatar
    Apr 2005
    Phoenix, AZ
    I'd go with krustydawg. I wouldn't recommend you install Windows on that hard drive until it's with the M1000 MB. Windows has a hard time switching motherboards.
    Make sure your CD-ROM is the first boot device. Make sure your WinXP CD is a bootable CD (not a burnt/copied CD).
    Oct 2004
    New Jersey
    XP will not work once you switch the motherboard. Once XP see's so many hardware changes it will assume you are trying to install on multiple machines and it will not authenticate your CD key and it will want you to call microsoft for a manual activation which is a huge PITA.
    Maximum Bitrate dodgetimes2's Avatar
    MI
    Quote Originally Posted by RJP350Z
    I highly doubt it, I've done it multiple times with no problems.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    although i havent had it happen to me (ive transffered a hard drive between 2 computers which both have similar specs. one is a gateway, another is dell. about same age), ive also been told that xp will have a hissy when the motherboard changes. better if you install it on the M1000.
    Your everyday carpc geek and tech guru at your service. *bow*
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    yes install it on the itx board and if it is a burnt copy. Get Ultra iso make it an image then go into nero and burn image correctly. Meaning go into nero burning rom and x out of what pops up then go to Recorder then Burn Image. Then click on the iso you have just made and there ya go.
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
  1. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-26-2006, 11:40 PM
  2. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 03:37 PM
  3. FS: Samsung SN-324 Slim Optical Drive
    By mammlouk in forum Classified Archive
    Last Post: 04-18-2005, 09:52 PM
  4. xp sp1a install + SATA drive = ??
    By Dexter in forum General Hardware Discussion
    Last Post: 03-02-2005, 01:26 AM
  5. Best remote DVD drive option
    By lookinco in forum General Hardware Discussion
    Last Post: 08-09-2004, 11:28 AM
