Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: Anyone hav wiring diagram using inverter?
    May 2005
    Hi i am new to this Car PC thing....i was just wondering if anyone has actual plans or diagrams to show all the wiring and connections using an inverter? Or can anyone recemond any threads or websites that may help me?
    Deep Dey
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    Battery + -
    Fuse +
    0/8 Guage Wire +
    Inverter + - < Body Ground
    Apr 2005
    Minnesota
    1. The wire going from the battery - (negative) (black) to the vehicle chassis is already done, so you don't have to worry about that.
    2. Now go to a car audio store and buy some amplifier power wire (preferably red) and an inline fuse for it. You also need to buy a connector that BOLTS down to the battery. Why not bring your inverter? If they have a knowledgeable staff they should be able to do the math and give you the right fuse and wire for your inverter...I can't really tell you because I don't know how many watts it is, anyway, buy some 8 guage wire, or maybe 4 gauge if you have a really power hungry inverter. You need to buy enough to run ONE wire from your battery to whereever you mount the inverter PLUS A FEW EXTRA FEET! You'll be glad you bought a few extra feet because you'll use it...
    (a) Cut a short piece of wire and strip both ends. Connect one end to the Battery Connector. Connect the other end to one side of the inline fuse. Strip an end of the remaining wire and connect it to the other side of the inline fuse. Now you must drill a hole through your firewall (if you do this you must use a rubber gromet so you don't ruin the wire and seal the hole as well), or find another way to run the wire into the cabin of your vehicle SAFELY! String the end without the battery connector into the vehicle to where you want to put your power inverter. Be cautious of where you run the wire in the engine compartment. HOT WIRE = BAD. After you are done running that wire, cut off any excess, then strip the end, and connect it to the invertor + (positive)(red)(note: this may require additional connectors).
    (b) Wait until you have completed step 3. Secure the wire in place with vinyl quick-ties. Then connect the battery connector end of this wire to the battery.
    3. You also need to buy some of the same size and grade wire in a different color (preferably black) this wire needs to be long enough to connect your inverter securely to the chassis of your car.
    (a) Attach one end of this to the - (negative)(black) terminal on your power invertor, connect the other end (bolt it down) to BARE Metal on your car's chassis. There can not be any rust or paint or it will not have a good connection. (Again, this may require additional connectors.
    Da_Kooz
    Apr 2005
    Minnesota
    By the way...you better appreciate that paint pic....haha...I tried to do a little ascii art first but it went all over the place when i tried to post it...
    Da_Kooz
    Variable Bitrate ENerd's Avatar
    Feb 2005
    Wichita, KS
    And attach this to inverter
    1994 Acura Integra GSR (Bone Stock)
    Alpine CVA-1005
    Alpine DVA-5205
    Dreamcast - MP3, MPEG and Games
    JBL DA1002-90
    10" Soundstream Tarantula T2-10
    Wiring by neema12
    Dec 2004
    Quote Originally Posted by ENerd
    have u seen that old enterprise rent a car commercial where they have an idea to send a computer to everyone in the states and an amish guy gets it and he asks his friend where does that plug go and he looks at the cows butt and sticks it in it and then u hear the cow go MOOOO and the enterprise logo comes on the screen
    May 2005
    ahh sick mate...thanks alot man! appreciate it, and yeah kick *** diagram no probs with it.
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    Quote Originally Posted by Deep
    Deep Dey
    Hey Deep,
    If you are interested in a more professional diagram showing all carputer components, check out the Ford Aspire install at Mobile-Effects.com
    Here is the link to the gallery featuring that car. There are a total of 9 pages of images for that car. The wiring diagram is shown on page 8. High quality, shows all the components.
    http://www.mobile-effects.com/module...view_album.php
    To view the gallery, you may need to sign up on the main page. www.mobile-effects.com
    It's free and takes 1 minute to sign up. No confirmation emails and no spam sent to your email that you register.
    Any further questions, pm me or email.
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
    Apr 2005
    To make it easier you can plug the inverter straight into the cigaretter lighter.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by Aus_Ben
    OMG NO!
    THIS IS BAD ADVICE
    AND CAN POTENTIALLY CAUSE A FIRE IN YOUR WIRING LOOM
    Low current devices are fine. SOmetimes even up to 20A. I would say 150W max on most lighter sockets. I have a 300W inverter with a lighter socket but I would never run it for a long time. The wiring on your socket is not going to be able to take a sustained hight current as well as a dedicated known gauge cable.
    You also do not know if there are any dry joints.
    A fire in your dash loom will destroy your car!
  1. inverter startup prob~!
    By bulgogi777 in forum Power Supplies
    Last Post: 10-15-2005, 03:20 PM
  2. inverter wiring question
    By yonu in forum Power Supplies
    Last Post: 03-17-2005, 11:02 PM
  3. Wiring Diagram of Inverter and AMPS. Will this work?
    By wonderworm in forum Power Supplies
    Last Post: 09-14-2004, 06:15 PM
  4. Inverter Wiring
    By MoniraInc in forum Power Supplies
    Last Post: 06-25-2004, 09:23 PM
  5. datalux 4x20 red lcd wiring diagram?
    By etrik in forum LCD/Display
    Last Post: 12-07-2001, 04:35 PM
