Results 1 to 8 of 8
Thread: how to hook up a computer to a sony tft screen?
    May 2005
    Can it be done and how? I have a xav-7w sony head unit and want to hook up a computer...would this be possible or do i have to get a touchscreen?
    Also...is there a way to hardwire a playstation to a car rather than using an inverter?
    THANKS!
    Constant Bitrate markopolo311's Avatar
    Apr 2005
    Atl GA
    YES! there is
    a) it can be done, but from what i can tell it's not a touchscreen, and anything with VGA will give you a better resolution.
    b) it can be done as well. The PS2 has an internal power supply which takes 120 volts AC and turns it to about 12 volts DC. so it jut means you'll have to crack open your PS2 and change some stuff. (sounds like fun for a newbie) The gamecube, i just thought i'd point out, has an EXTERNAL power supply, so no hacking is nessecary to put it in a car
    I'mmmmmm a n00b.... feel free to make fun
    May 2005
    any idea on how to perform the PS hack? Oh yeah...its not a PS2...its the original.
    Thanks!
    Constant Bitrate sagekoala's Avatar
    Aug 2004
    Des Moines, Iowa
    well if its a normal playstation ... remove everything that isn't a power supply from the playstation ... then plug it in! use a multimeter to find out what voltages you need to supply to it, then supply those voltages and you are done.
    if it is a psOne then find out whatever the external psu outputs and then supply that.
    or make your life easier and just get an inverter. If it needs anything other than a standard 12v just use an inverter ... but i guess what fun is that.
    blah (this reply is brought to you by an attempt to NOT study for finals tommorow)
    don't worry i know i usually don't make much sense
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    I agree. an inverter is a good way to go here. Open the PS up and see if there's an onbius power bus somewhere. if not, your probably out of luck.
    Constant Bitrate 00christian00's Avatar
    Apr 2005
    Italy,Ancona
    Why not buy the cigarette lighter adapter for the psx?
    May 2005
    well I have a PS that I wanted to hook up directly to the car and the Im also hooking up a dvd player and cd player using the aux outs to go into the inputs on my sony xav-7w. What do you all think? I just want to have a Playstation (already there with an inverter) and a dvd and cd player(not changer). My next project is to build a custom shelf for the playstation where my glovebox is. Oh yeah, i have a 1997 chevy camaro. Thoughts?
    May 2004
    NJ
    You need regulated source of power, the car power fluctuates a lot and not clean - this is the short answer. Go with what 00christian00 said, nice and clean.
  1. Bought a TFT screen - what is it?
    By code- in forum Newbie
    Last Post: 05-22-2004, 05:54 PM
  2. Replies: 0
    Last Post: 05-19-2004, 12:55 AM
  3. Difference between STN and TFT screen?
    By noodles in forum LCD/Display
    Last Post: 10-23-2003, 05:32 PM
  4. Replies: 2
    Last Post: 09-24-2001, 11:22 PM
  5. All In one touch screen flat screen computer for cheap
    By crazyshaxs in forum General Hardware Discussion
    Last Post: 04-25-2001, 12:38 PM
