Results 1 to 10 of 13
Thread: Setup Help
    Constant Bitrate trance728's Avatar
    Mar 2005
    Huntington Beach, CA
    Setup Help
    I'm still waiting for the rest of my setup to come in the mail, but for now I have the motherboard, psu, and screen, and I just wanted to play around with it so I grabbed a spare harddrive and dvd rom. I'm using a epia m10000 board and I'm trying to setup windows on the hd, the bios screen loads fine but it won't boot to the windows setup at all. This is my first time ever building a computer so I have no idea if I'm missing a step or something, the bios is setup to boot from the dvd drive first so I don't know what else to do, please help me.
    Constant Bitrate CapitaineFritz's Avatar
    Feb 2005
    Laval, Quebec (Canada)
    Does it try to boot from the CD-Rom ? Do you see any flashing light coming from the CD-Rom drive when the bios is starting ? To enter Windows XP setup, it should be written something like:
    Booting from CD-ROM:
    Press any key to enter setup...
    for about 3seconds. Then if you press a key you'll enter the setup.
    Do you get any error message ?
    Do you have an original Windows CD ? Some copied CDs might not have a boot sector on them..
    Mar 2005
    its a copy, is there any way to get the boot sector on a copy
    Low Bitrate microbionic's Avatar
    Aug 2004
    medina,ohio
    if your using the lcd touchscreen, you need to set it up in the bios first for it to work past the bios screen, at least i had to for my setup, m1000 epia, lilliput combo
    CarPuter ProgressO meterO
    [+++++++++] 100%, 1Ghz Epia M,opus 90w, Earthmate GPS, 7 inch lilliput molded into dash, anything i forget?
    visit me on the web at
    http://gozips.uakron.edu/~cmk23/
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    Did you go in the bios and make your primary boot device the cd-rom?
    Edit: Oh yeah, I forgot, to change the boot device, you need to go in your bios setup (press delete or the button it tells you when your at the black screen when you boot your computer).
    Than you go in Advance BIOS Features(or something like this) (2nd or third on the left).
    Than look for First/Second/Third Boot other device, or Primary Boot device, or something similar.
    Than choose the cd-rom drive (should be d: since you have one hard drive, could be something else, like e: or f: etc...)
    After That go back to the start and do save and exit.
    Last of all, Its gonna ask you if you want to boot from the cd-room, press enter or space or any other button. Setup starts after this.
    Variable Bitrate ENerd's Avatar
    Feb 2005
    Wichita, KS
    Make sure the burnt cd works on another system. If it does use that CD Drive to load Windows. I'm pretty sure its the CD and/or Drive that is causing the problem.
    1994 Acura Integra GSR (Bone Stock)
    Alpine CVA-1005
    Alpine DVA-5205
    Dreamcast - MP3, MPEG and Games
    JBL DA1002-90
    10" Soundstream Tarantula T2-10
    Wiring by neema12
    Mar 2005
    on my normal computer it doesn't load to the windows setup either, but I know I've used it before and its worked, but this is a different copy of the disk. is there any file that should be on there to make it load from the start?
    Feb 2005
    Wichita, KS
    I have the same problem with my cds. It will work max two times then it'll stop working. I just reburn the original and it should work again.
    Alpine CVA-1005
    Alpine DVA-5205
    JBL DA1002-90
    Wiring by neema12
    Mar 2005
    the original is about 1250 miles from here, i had my bro just put the contents of it in a rar file and send it to me then i made a cd from it, guess ill have to have him mail the original
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You could actually purchase the software...
    Want to:
  1. Ok setup? What Power supply?
    By untal3nted1 in forum General Hardware Discussion
    Last Post: 01-01-2005, 07:17 PM
  2. Carputer setup critique?
    By carterparks in forum General Hardware Discussion
    Last Post: 12-30-2004, 12:08 PM
  3. help with my wifi setup?
    By ŠuTcH in forum Wireless Communications
    Last Post: 12-06-2004, 12:10 AM
  4. Advice on Setup...
    By blackout03specv in forum Newbie
    Last Post: 06-29-2004, 10:36 PM
  5. Renault Laguna Puter Setup check
    By Noctris in forum Newbie
    Last Post: 05-24-2004, 06:05 AM
