Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: EPIA does not boot - Only fans come on
  1. #21
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    have you tried reseting the cmos ? .. theres a jumper on the M/B, change it to to pins 1-2 (I think.. well if on 2-3 then 1-2 else 2-3). Then power the comp up.. nothing happens.. then swap the jumper back agan.. then poer up and hey'presto its working again.. I think you will find this will solve your problem !
    CdR
    (if not go get a beer and reside in the fact u got a serious problem ! )
  2. #22
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    Thanks for all the suggestions. I will try them and report back.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
  3. #23
    Jun 2004
    I'm very new to this but, if you're still having problems, try what Menthol suggested above. It sounds like you've had this PC for a while now. I had an older PC in my home a few years ago that displayed a very similar behavior. After trying everything, I finally gave up and tried swapping out the only thing I hadn't already replaced, the CMOS battery. Crossed my fingers, hit the power button, and it worked. I know car PCs aren't exactly the same, but they're close enough that it may just work. Plus, you'd only be out about $5.00 for the battery.
  4. #24
    Constant Bitrate blasterguy128's Avatar
    Feb 2005
    Fort Lauderdale, FL
    Quote Originally Posted by CdRsKuLL
    Doing that as we speak....Damn thing just won't boot for anything. M1-atx problems drive me
    Mobo= Epia V
    Ram= 640mb
    Ps= m1-atx
    Screen= Lilly 7" ts
    Hd= 40gig
    case= 1/10 scale model of my car (04 Saturn Ion QC)
    soundcard= soundblaster mp3+
    GPS= Holux gm-210
  5. #25
    Dec 2004
    Bay Area, CA
    Quote Originally Posted by blazin j
    My PC is about 2 years old. I suppose that is old enough given the extreme temprature variance inside a car. My five year old home PC does not have any problems though. I have the battery replacement on my list of things to do. I have spent so much time on this project away from my family that my wife has forbid me from going to the garage and working on the car.....
    Had no idea I was wanted...
  6. #26
    Nov 2004
    Northern VA
    I'm having this same problem.
    I've tried a new battery, reset the cmos, checked the ram, tried a new power supply - nothing seems to work.
    I've booted without the ram - same result.
    The only thing I've found that SORTA works is booting without the HD connected. Then the thing will actually beep and boot (until it needs the OS) but this only works SOMETIMES.
    So anyone have any ideas? Could it just be that my car battery is dying and can't push the PC anymore? This seems unlikely to me, as the car starts fine.
    Thoughs?
  7. #27
    Nov 2004
    Northern VA
    Update:
    Well it's not my car battery, as I hooked the PC up to the AC/DC brick that came with the orginal power supply and it still didn't work. I disconnected everything from the motherboard that required power (drives, USB devices etc) and the ****** still won't boot consistantly.
    I've reset my cmos several times. I really don't get it. If something were fried, I would think it just wouldn't work at all.
    I've looked in to the grounding issue some, but I really don't see how something could be grounded out on the thing...
  1. EPIA 5000 boot problem
    By linden_arden in forum General Hardware Discussion
    Last Post: 08-08-2008, 05:57 PM
  2. epia network boot
    By belmontboy in forum General Hardware Discussion
    Last Post: 03-08-2004, 09:58 AM
  3. My EPIA M10000-N won't boot?
    By erains in forum General Hardware Discussion
    Last Post: 01-26-2004, 06:52 AM
  4. What bios options for fast boot on EPIA M-1000
    By ugosplat in forum General Hardware Discussion
    Last Post: 08-13-2003, 08:42 PM
  5. EPIA Full screen boot logos...
    By Defiler in forum Software & Software Development
    Last Post: 12-07-2002, 01:54 AM
