Are those fans 12v? If not, you're going to burn them out pretty quickly.Originally Posted by llajumpvid
If you're going to power the fans after the car is powered off, you wouldn't want to use the ACC wire and you'd have to purchase or design/build a timer circuit. Basically when it sees there's no power on the ACC line it would wait X amount of time and then cut power to the fans.
Now, if you decide to use an Opus power supply, it has a delayed shutdown, which accomplishes the exact same thing....
LinkBack URL
About LinkBacks
