Results 1 to 10 of 16
Thread: OPUS Power Supply & 18 Volts
    May 2005
    Tampa, FL
    OPUS Power Supply & 19 Volts
    I'm going to be using a Xenarc MP-SC8 in my project, but it requires a 19V feed. Does anyone have any experience with this box, and the power supply? I can't find any information on it on the Xenarc webite. I ordered the DC to DC adapter from them, but I don't know if it has any of the functionality of the OPUS power supplies to monitor voltage and condition the line. I'm wondering if I can or need to put an Opus in front of the Xenarc DC to DC adapter, and if so whether it will still provide the same functionality. Ideas?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    BIG HINT: CARNETIX
    EDIT: please ignore the following comment as i didnt realise this is in the noob section
    for **** sake.
    Mar 2004
    Bristol
    just to help even more...http://www.mp3car.com/store/product_...products_id=94
    (as you will see it is cheaper than the Opus too)
    May 2005
    Tampa, FL
    Thanks for the "BIG HINT". I hadn't come across anything on Carnetix in the past few weeks.
    BTW - No harm, no foul. I know some of my questions are very elementary at this point, but I'll eventually be able to contribute to the forums as I get farther into this project.
    Mar 2004
    Bristol
    What is the spec on the xenarc Pc you are getting?
    The dc-dc you ordered from Xenarc is probably like a laptop dc-dc so it will have no SDC stuff or as good low input performance (ie for cranking). If it is a laptop dc-dc then the 140W carnetix should be fine.
    May 2005
    Tampa, FL
    Pentium 4 Based, Small Footprint: 5.82"x10"x2.79"; Built-in Audio & Video, 6-Channel Surround sound, 10/100base-T Ethernet, 3-USB 2.0, 1 Fire-Wire, 1 SPDIF, 1 Mic-in, 1 Headphone out, 2 PS2, 1 Serial. 19V DC power input.
    Dimension (in): 5.82(W) x 10(D) x 2.79(H)
    Operating Temperature: 32°F ~ 122°F
    Weight: 3.3 lbs (barebone)
    Intel 865GV / ICH 5 Chipset
    FSB support up to 800Mhz
    Full support of Intel Hyper Threading Technology
    Dual Channel DDR support
    Processor: Pentium 4 (2.8Ghz)
    Memory: 1GB
    Video: Fully AGP v2.0 compliant, high performance
    256-Bit 3D/128-Bit 2D graphic engine, dual video overlay
    windows for Mirror Mode display
    Audio: Software AC 97 Audio CODEC
    Storage: One 2.5 inch Slim Hard Disk
    (Support ATA-33/66/100. MPSC8P only supports 2.5” HDD)
    Power input: 19V DC
    Chassis: Ultra light extruded Aluminum
    Xenarc TSV-700 touchscreen
    I opted for this setup due to the PCMCIA slot. I wanted to be able to use my Verizon wireless card for Internet access w/o being near a hot spot. I can't find any information about the Xenarc 12VDC to 19VDC power supply on their site.
    May 2005
    Tampa, FL
    This is what I'm planning. If anyone sees potential problems, or has any suggestions, or comments,.......
    Please let me know.
    Mar 2004
    Bristol
    looks ok. i think.
    did you see the thread on the 5V addon for the carnetix? it will provide a third output at 5V (so you can set the secondary to 12V) and then you can power a USB hub/GPS etc etc.
    May 2005
    Derbyshire, UK
    One point about your connection diagram. The Carnetix has a dlyon output which would be better for the amp remote switch on.....
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
    Mar 2004
    Bristol
    yeah good point. that should avoid the amp thud.
  1. Buying an Opus Power Supply outside of the States.
    By Diewlay Lowmo in forum Power Supplies
    Last Post: 03-30-2006, 06:56 PM
  2. Features of the Opus Power Supply?
    By senseless228 in forum Power Supplies
    Last Post: 04-19-2005, 07:38 PM
  3. OPUS power supply
    By devin99 in forum Power Supplies
    Last Post: 09-03-2004, 11:31 PM
  4. Replies: 8
    Last Post: 11-04-2003, 12:03 PM
  5. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
