Results 1 to 10 of 15
Thread: Blue cable?
    Jul 2003
    Earth
    Blue cable?
    My carputer plans are progressing slowly due to finance but in the mean time i want to run my car audio system from my mp3 player....
    Can i just plug it in to the amp as in the diagram in the post above? Someone told me there is a cable that plugs into the amp from the headunit that tells the amp to turn on......and well i wont be using a headunit.
    My system:
    Iriver mp3 player with line out
    6 channel amp
    door speakers
    6 by 9
    1 sub
    Will my amp be on all the time even when the car is not running and so flatten my battery?
    Many thanks!
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    u need to hook it up to a ACC fuse that turns on when u turn ur car on and turns off when u turn ur car off
    Jul 2003
    Earth
    an acc fuse? Is this a standard hardware thing can i just walk into a local car audio place and get one?
    Thank you!
    Nov 2004
    amps just need a 12 volt trigger, if you want you can just wire the blue wire to a yellow wire on a molex connector on your computer
    Jul 2003
    Earth
    But what if i wanted to use my portable mp3 player and not a pc......how would i get the amp to turn off an on?
    Dec 2004
    Quote Originally Posted by Blop
    Thank you!
    check under ur dash man an acc fuse is just a fuse that gets power when u turn ur car on for example - power windows - radio - wipers stuff like that
    Jul 2003
    Earth
    i see cheers....
    Dec 2004
    good luck !
    Jul 2003
    Earth
    So if i go through my fuse box to find a fuse thats connected to a 12v line and run a wire from that to my amp....i should be fine?
    Dec 2004
    well everything in ur fuse box will have 12 volt
    you need 12 volt that turns on when u turn ur car on that way ur amps are only on when ur cars on and it wont drain your battery
    usualy ur wipers - power windows - radio are only on when ur car is on try to ind ur wiper fuse and tap into that
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. where should i go to get a cable?
    By blackpacu in forum LCD/Display
    Last Post: 09-08-2004, 01:25 AM
  3. FS: 25' CAT5 IDE Cable & 3.5" PVP Player! CHEAP!
    By 1300mer in forum Classified Archive
    Last Post: 08-13-2004, 02:47 PM
  4. Wanna extend your Kiosk 12.1" LCD cable?
    By CDesigns in forum LCD/Display
    Last Post: 05-13-2004, 10:10 PM
  5. A cable I found.
    By masterful in forum LCD/Display
    Last Post: 08-17-2003, 10:36 PM
