Results 1 to 3 of 3
Thread: just about wiring to power...
    May 2005
    hi im fair new to this...urmm i was just wondering im going to use an inverter to power my computer..how exactly do u like attach the leads of the inverter to the battery cuz like ther these big jumper lead type thingies if yas get me cuz you have like the cars power cable connected to it also..thers like no room? and also i want to like mount a switch on my dash were i can press it and my computer will start up...ideas on how exaclty to do that..i dont wanna get one of those startup/shutdown controll thingies as i am on tight budget!
    thanks alot
    Sep 2003
    Elgin, IL
    prob best to cut em of and replace em with a o ring connector.
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    Regarding the inverter wiring:
    Just cut off the connector. Before you do though, mark positive and negative, or you will wind up with a blown fuse (nothing too bad, just saving a couple $). Crimp a loop connector on the negative wire, and ground it. Then for the positive, wire it into a positive lead. Use a butt connector, distrobution block, or whatever, just a fused, positive lead.
    Regarding the startup/shutdown:
    This is easy to do. Get an automotive relay. It will have five prongs. Connect terminals 30 and 87 (iirc) to the two power button pins on your computer's motherboard. Then use the button to power the relay. So when you push the button, the relay will connect the two power pins on the computer, and it will start. If you have an aftermarket alarm system, you can wire up the aux button on it to start your computer just as easily. Cost: $4 for the relay, and maybe some wire.
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Casetronic C137 120watt power supply
    By Change in forum Power Supplies
    Last Post: 11-13-2005, 09:15 PM
  3. Wiring power up a Jetta.
    By ericthebikeman in forum Power Supplies
    Last Post: 07-19-2004, 08:08 PM
  4. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 05:59 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
