I don't think it will work unmodified. I did some Googling (I recommend you do the same) and found some people asking about that Shuttle unit's compatibility with AMD XP-M CPUs. They were all in French, and I don't feel like translating for you.Originally Posted by gaki
The 90w would be a little underpowered I believe. I could be wrong. Your CPU alone is going to be pulling 1/2 of the available 90w. Just something to consider.Would the M1-Atx 90w PS be sufficient enough to handle this setup plus a 2.5" hd and a slim dvd/cdrw? Or should I go with the CNX-p1900?
Do some more reading.
That depends. You want to make certain that the CPU is going to be cooled enough to work in your car on a hot day. I don't think you need to go balls-out and use a Swiftech 462, but some cooling is necessary.What should I do in terms of cooling? Do the mobile processors get hot enough to warrant a sizable heatsink w/fan?
LinkBack URL
About LinkBacks
