5s/2hrs means that the PC will receive the shutdown command 5s after you switch the ACC wire off. If your PC is configured correctly it should proceed through a normal shutdown cycle. If your PC fails to shutdown correctly, it will be forced off after 2 hours when the PSU will force all of its power rails off.
LinkBack URL
About LinkBacks
