Results 1 to 4 of 4
Thread: Carputer Advice Needed
    Jan 2004
    I am looking into building my first carputer. I will be putting this in my 99 Hyundai Tiburon, and if all goes well I will build another for my 2005 Scion XB. I would like to build a MicroATX system so that if I want to I can bring it in the house. I think I would like to keep my headunit, possibly relocated, and use the auxilary input for the sound from the computer.
    Here is what I have come up with so far:
    MSI K&N2GM-V Socket A NVIDIA nForce 2 IGP Micro ATX
    WD Caviar SE WD800JD 80GB SATA150
    Rosewill 512MB DDR PC3200
    AMD Mobile Athlon XP-M 2200+ (35W)
    Athenatech A100SC.200 MicroATX with 200W PS
    I would like a 7" touchscreen VGA for control/visuals. More than likely would be putting in a laptop style DVD drive underneath the monitor. All I seem to be able to find for these though is the tray load, does anyone make a slot load?
    I already have a GPS setup and software to run with it, as well as a external OMNI wireless antenna. The antenna I have was used for hooking to an Orinoco PCMCIA 802.11B card. Are there any PCI cards that will allow me to use this antenna?
    I've got Windows XP Professional, Home, and Media Center Edition. Which would you use? Or would you go with a Linux based OS?
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Firts who said that you can no bring a ITX system in to the house....??
    The OMNI ant can be use if you change the connector to fit the PCI card.
    Some people here like to go with fix OS like (lite,minilogon) and some other like to have full OS (winxp) 'cause since home is a reduce copy of Pro and MC it just have some adds to make look more user friendly towards media interaction................I will say think what you going to be doing with the car pc and choose drom there.
    Jan 2004
    I will be using it mainly for music, video, and navigation. I will occasionally use it for databasing and invoicing for my business. I would like to be able to synch with my home computer when I pull into the drive way. So I am thinking Windows XP would probably be the best to have loaded on it. Maybe a dual boot with linux so I can offer wireless security audits to my customers. I am good at building home computers and servers so mainly what I need assistance with is the power supply portion.
    Nov 2004
    Javageek check PM
  1. Noobie Questions, Advice needed
    By Phoenix_MR2 in forum Newbie
    Last Post: 03-09-2005, 01:36 AM
  2. How many amps needed to power carputer?
    By msumr282 in forum Power Supplies
    Last Post: 12-02-2004, 11:05 PM
  3. Project Car needed some gearheads on Carputer
    By FastAttack in forum Newbie
    Last Post: 11-04-2004, 12:33 AM
  4. planning a carputer, input needed!
    By russell1337 in forum Fabrication
    Last Post: 09-21-2004, 10:42 PM
  5. Newb carputer set up, advice & help needed.
    By Rykielz in forum Newbie
    Last Post: 07-26-2004, 03:26 PM
