Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 53
Thread: Newbie's completed Tiburon project
  1. #21
    Low Bitrate Gagaza's Avatar
    Jun 2005
    CA, USA
    Quote Originally Posted by Noldona
    I have 2 comments to say. 1) Take off those curb feelers on the front of your car, in my opinion they look stupid, and 2) CAN WE SAY BANK!!!!! I wish I had the cash to spend on stuff like that. Right now I am trying to save cash just to buy puter parts.
    Also what software was it that you were using? looked like a good layout for controlling everything.
    1) Those are support rods that serve a purpose and in my opinion look good. They are staying on. 2) MY BANK!!!!! account doesn't afford for me to start taking off parts that I planned for and spent good money on, just because a stranger doesn't like it or understand it.
    To answer your question, I'm using Centrafuse as mentioned in post #1 of this thread.
  2. #22
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    Gagaza,
    That looks great man, job well done, like everyone else said, the fit and finish of everything is superb, and those doors are just awesome. I would venture a guess that you did a lot better job than they do on Pimp My Ride when they do those doors.
    Anyway, keep it up and welcome to the forum, as you already noticed, there is a HUGE wealth of knowledge that you can tap into.
    Look forward to seeing more of your work!
  3. #23
    Jun 2005
    CA, USA
    Quote Originally Posted by kirbycope
    Everything is nice except the inverter
    kirbycope, is the inverter a bad thing? Should I switch to a dc-dc power supply? I do have a concern about heat. I will be adding a big fan to exhaust the heat. Will there be enough of a heat reduction by changing my power configuration to warrant the change? Or should I just look at cooling solutions to address my concern. I wasn't sure what your comment implied, but It got me to thinking about the heat inside my case. Thanks in advance to anyone that shares useful input/opinion.
  4. #24
    Aug 1999
    Gagaza,
    I know you asked for kirbycope's answer, but I will chime in and say that you HAVE to go to dc-dc. It is simply, a more efficient way to power your carpc. I would also recommend keeping the inverter so that you can hookup other devices while you are in the car, such as xbox, ps2, etc etc
    The 2 big mass produced brand/models of dc-dc are Carnetix p1900 and Opus Solutions 75w and 150w
    Good luck.
  5. #25
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    Quote Originally Posted by shred444
    damn gull wing doors. nice
    not gullwings...they're lambo style, or "verticals"
    gull wings are whats on the delorian.
  6. #26
    Jun 2005
    CA, USA
    Quote Originally Posted by defsquad
    Gagaza,
    Good luck.
    Actually I was soliciting opinion from everyone that would care to comment. I just quoted kirby cuz he's the one that got me to start thinking about it and after reading bugbytes post on power supplies.
    Thank you for you're response. I'm currently in full agreement with your opinion. I was thinking of keeping the inverter and placing it up near the front, maybe under the seat. I'de also plug in a powered usb hub, the monitor, and cd burner\dvd thats mounted in the glove box.
    Would anyone else care to chime in. Is there any reason to not switch, aside from cost? Can I use 2 dc power supplies. One for the motherboard only. If I had known that there was such a thing as a dc-dc inverter I would have used one in the first place. I'm glad to have found this forum and am looking forward to some solid advice.
    Edit: Looks like I'll have to use inverter due to 150w dc limitation. My system requires more. I'll have to come up with a good cooling solution. Maybe a/c piped into the well, or something like that. Can I get some ideas please?
  7. #27
    Jun 2005
    CA, USA
    Can I please get input on my power configuration? Should I keep it as it is, or should I/ can I switch to dc-dc? Will an opus 150w be enough for my atx motheroard with an amd 2.8 ghz cpu. Do I need to give more specs to get feedback? Can I use another dc-dc power supply for my cdrw/dvd drive and hard drive. I've read and searched and am still in need of help.
  8. #28
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Well, it looks like you're either stuck with the inverter or you have to split the system up among several power supplies.
    I'd stick with the inverter, if it's working for you. Are you able to do auto startup/shutdown? If not, think about getting a DSSC from the online store.
    With a car that sweet, you just gotta figure out how to incorporate the monitor directly in the dash. You've got absolutely everything else in there!
    Want to:
  9. #29
    Jun 2005
    CA, USA
    Quote Originally Posted by Bugbyte
    Bugbyte thank you so much for your input. You make great sense. I'll stick with the inverter. It works great as is. I haven't had any problem at all.
    I'll just address the heat issue. I have some ideas for cooling. Plus I can remove the plexiglass during hot days. Would anyone care to share any ideas for cooling?
    Also, I think I figured out how to fit the monitor into the dash. I just won't be able to get to it for awhile. I'll post pics when I getter done.
    Amd 2.8 ghz, 120gb hd, 512mb ram, 10.4" xenarc, Audigy 2 nx.
    Check out my system http://www.mp3car.com/vbulletin/newbie/51876-newbies-completed-tiburon-project.html
  10. #30
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    For cooling, I'd drill holes in the plexiglass and then use some temperature monitoring software on the PC. If it's a problem, then add a fan or two.
    WizardPC experimented with cooling using his air conditioner and cutting a hole in the floor of the car to cool his PC. Here's a link: my ideas to combat heat
    Want to:
  1. PROJECT ST34LTH : Project Car Purchased w/PICS
    By ST34LTH in forum General Hardware Discussion
    Last Post: 09-01-2008, 10:09 AM
  2. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
  3. New Project: Contrast Mediaplayer
    By pplante in forum Software & Software Development
    Last Post: 07-07-2004, 12:06 PM
  4. Carputer as a comp sci final year project?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:19 AM
  5. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 06:43 AM
