Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 53
Thread: Newbie's completed Tiburon project
  1. #31
    Low Bitrate Gagaza's Avatar
    Jun 2005
    CA, USA
    Quote Originally Posted by Bugbyte
    For cooling, I'd drill holes in the plexiglass and then use some temperature monitoring software on the PC. If it's a problem, then add a fan or two.
    WizardPC experimented with cooling using his air conditioner and cutting a hole in the floor of the car to cool his PC. Here's a link: my ideas to combat heat
    Thanks Bugbyte, I've mounted three fans into the plexi. Two intake and one huge aluminum fan for exhaust. Haven't installed monitoring system yet. But, it's still hotter than I'm comfortable with.
    Taking the rear half of the plexi off actually takes care of the problem. I'de still like to build something cool and keep the case covered.
    Just noticed the link. That's great that someone is already working on using a/c. Although I'm not willing to cut a whole in my floor. I'll go read it.
    Thanks again Bugbyte. Sorry my search didn't find that thread. I appreciate the help.
    Amd 2.8 ghz, 120gb hd, 512mb ram, 10.4" xenarc, Audigy 2 nx.
    Check out my system http://www.mp3car.com/vbulletin/newbie/51876-newbies-completed-tiburon-project.html
  2. #32
    Jun 2005
    CA, USA
    Bugbyte thanks again for the help. That was the perfect thread for my questions. I'll do a better job of searching next time. Just an FYI for anyone interested, my final decision is to not change my set up at all. Everything works so perfectly as it is. No need to put a fancy cooling system.
    Check out my system http://www.mp3car.com/vbulletin/showthread.php?t=51876
  3. #33
    Jan 2004
    great install gagaza, looks very clean and custom. I like the trackball/media buttons, is that a remote or a part from a keyboard?
  4. #34
    Jun 2005
    CA, USA
    Quote Originally Posted by wariow
    Thanks. The mouse is a remote. Here's a pic from the Targus site.
  5. #35
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    That's a cool mouse..!
  6. #36
    Jun 2005
    CA, USA
    Quote Originally Posted by RS3RS
    Yeah the mouse works great for my set-up. It has a 50' range. I can run my system from outside the car, like when I'm looking at my system from the hatch. I've also taken it with me to do powerpoint presentations, that's the only time I use the built in laser pointer. Having mouse, multimedia, and presentation modes really give me lots of use for this mouse.
  7. #37
    Jan 2005
    That is all around a great car. Job well done.
  8. #38
    Jun 2005
    CA, USA
    update
    Just an update on my system status. I was previously concerned with the upcoming summer heat. It's now reached over 100 degrees a few times. The system hasn't had any problems at all. Looks like I won't need to do anything more to my system, as far as heat is concerned. This is just an FYI to anyone interested
  9. #39
    Jan 2005
    How is your cd burner/dvd player in your glove box wired? Why do you have one in the glove box and one in your trunk?
  10. #40
    Jun 2005
    CA, USA
    Quote Originally Posted by Silver Wing
    I added the one in the glove box so that I would have access to it without having to leave the cabin. The one in the trunk was part of the initial build. There was no reason to remove it.
    The one in the glove box is hooked up to a powered usb hub along with the visor keyboard. I mounted it to the ceiling of the glove box and it's only a half inch thick, so it leaves lots of room in the box. It's hardly visible. The hub and cdrw/dvd are powered with an inverter that is hidden on the floor, inside of the center console and hooked up to the car battery. Remember, I didn't know about dc/dc inverters when I built.
    I still need to install my rear view camera. Can I get some opinions. It would fit perfectly in the keyhole. Should I use the keyhole or should I put it near the license plate? Is there a better place? Please give me your opinions. Thanks.
  1. PROJECT ST34LTH : Project Car Purchased w/PICS
    By ST34LTH in forum General Hardware Discussion
    Last Post: 09-01-2008, 10:09 AM
  2. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
  3. New Project: Contrast Mediaplayer
    By pplante in forum Software & Software Development
    Last Post: 07-07-2004, 12:06 PM
  4. Carputer as a comp sci final year project?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:19 AM
  5. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 06:43 AM
