Results 1 to 10 of 13
Thread: power to computer
    Variable Bitrate markland556's Avatar
    Jun 2005
    Bellevue, WA
    Question power to computer
    ok, well i have a 300W inverter and i was going to use that. Then i see these DC-DC power supplys. That seems like alot better solution. I used one of those online calculators and it said 275 is the max it would ever use. I have like a 125W PSU in it right now (its an Emachines) and i dont wanna spend alot of money on parts that i cant carry over when i build a custom system just for my car. I just really wanna know what kinda route i should go. Stick with the inverter of go with DC-DC PSU. Im going to be getting a shutdown controller too for the computer. This one here:http://www.dashwerks.com/dw_dssc.php
    edit** just found this HERE would that work for the PSU?
    Any help would be appreciated.
    Variable Bitrate fromplanetbob's Avatar
    Jan 2005
    that 200w power supply DOES NOT REGULATE THE 12V SUPPLIES.
    I'd suggest getting an OPUS 150W supply. And going with laptop drives and a laptop cd rom drive, with those you should have more than enough power. Plus the OPUS includes a shutdown controller built in!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    If you're under 150 watts, go Opus 150.
    If you're over that, go inverter.
    Check the "FAQ Emporium" on this site for info on powering your PC.
    Want to:
    Constant Bitrate CapitaineFritz's Avatar
    Feb 2005
    Laval, Quebec (Canada)
    I run my whole system (including monitor) out of a M1-Atx 90W psu
    Via Epia M10000 / 512 DDR / 10gigs 3.5 HD / M1-ATX / Innovatek 7" TS Screen
    Trunk fiberglassing in progress...
    Need GPS / Aux Input / WiFi
    My Corolla Computer
    Jun 2005
    Bellevue, WA
    well im kinda streaching my limits on funds for all this. so i think im going to go with the inverter for now and ill get the OPUS when i have enough money.
    Also does the OPUS have all the same features as that shutdown controller does?
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    If you get the money to spend, an OPUS really is worth the price. Of course, if you put a lot of work into it, you can get pretty much the same thing from an invertor. OPUS is just quicker/easier to set up. If you know what you're doing, you can get a setup just as good (though not as efficent) as an OPUS.
    Jun 2005
    Bellevue, WA
    well whats the big hype with OPUS, why not this one??
    http://www.mp3car.com/store/product_...products_id=94
    its about $100 cheaper than the OPUS
    Elsewhere
    Quote Originally Posted by markland556
    Read the specs.
    The Carnetix is designed to work with certain cases that have a power module in them (like an M1-ATX).
    The Opus will work on any ATX motherboard (assuming the setup meets power limitations... You're not going to be powering your P4EE 3.0 with it!).
    Why the big hype witht he Opus?
    It's an all-in-one power solution, albeit with limited power output. It has a shutdown controller. It survives crank. It's got battery protection. It will start your PC when you turn the key. Opus Solutions stands behind their products and is very helpful (reading the forums confirms this).
    How about the Wiki?
    May 2005
    Estonia
    does OPUS have remote out to power on amps? if it has, is it delayed 1-2 sec to elliminate loudspeaker bumps?
    FLAC J187's Avatar
    Nov 2004
    Boston
    Not sure why you'd wan't to run you remote from your opus? Why wouldn't you just tap off the car??
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
  1. Cutting power to USB after computer has shutdown
    By lookinco in forum Power Supplies
    Last Post: 05-17-2006, 02:05 PM
  2. Switching from Car to House power?
    By Deadnick in forum General Hardware Discussion
    Last Post: 01-11-2005, 09:09 PM
  3. Replies: 0
    Last Post: 06-14-2004, 11:36 PM
  4. howto? Power controller of kiosk computer
    By Marsupial in forum Power Supplies
    Last Post: 05-20-2004, 07:40 AM
  5. Does inverter draw power when the computer is turned off?
    By phoTToniq in forum Power Supplies
    Last Post: 08-14-2003, 05:49 AM
