Results 1 to 7 of 7
Thread: Power question
    Jun 2005
    Power question
    Hello, I have an idea for supplying power to my car computer I am building but I wanted to run it by the experts first so I don't break something.
    I now realise that my ITPS is pretty much worthless so I started to look for an alternative source of power, I just noticed that there is a "Power point" in the back of my car (VW Golf). I checked the manual and it is rated for up to 120 watts. I know it says 12v but I wondered if it was regulated, is it really 12v? If so, would there be a problem if I just hooked it up to my PW 200-M? I only need 80 or so watts.
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    if its a cig lighter plug then go ahead tap into it its 12volts :-D thats how i did my friends magnum install tap into the 12 volt for the screen and the pc runs perfectly hes using a opus90
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I have the same power point in my VW Beetle. I run my Epia setup on it with a Carnetix 1260 and a PW-120. Works fine. I ran it that way for a couple months, then eventually ran a dedicated thicker set of wires to it just to be sure.
    BTW, if you already have a power supply, take a look at the Carnetix adaptors. I changed from ITPS to Carnetix and it works great.
    And subtract 1 point from your newbie status for recognizing that ITPS is a piece of junk!
    Want to:
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    best thing to do would be to get a multimeter or voltmeter and test the voltage of the power socket while the motor is running.
    Dec 2004
    Quote Originally Posted by binary.h4x
    good answer :-D
    Jun 2005
    Thanks for the help, now onto the next question.
    Does anyone happen to know what the max power draw of an EPIA MII 12000 is? (like when it is playing DVDs). I am calculating out the power draw of my system right now (I am amazed at the generous ammounts of power the mini box power simulator allocates) so far the 2 HDDs and the FDD only takes 11.04 watts on the 12v rail and 7.35 watts on the 5v rail.
    Edit: *notice the calculated wattages are running, not spin up
    Edit(again): Found DVD drive power requirements, 800 mA (4 watts)
    still need power requirements for the motherboard (EPIA MII 12000)
    Jun 2005
    Bump, does anyone know the max power draw on the various rails for the MII 1200?
  1. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 12:08 AM
  2. The Newbie with another power question
    By nixneon in forum Newbie
    Last Post: 03-21-2005, 11:05 AM
  3. Noob question about power supplies
    By Jagojon3 in forum Newbie
    Last Post: 03-08-2005, 11:35 PM
  4. Power consumption question
    By S4Per in forum Power Supplies
    Last Post: 02-16-2004, 05:08 PM
  5. Question about power and inverters and all that
    By SBmp3 in forum General Hardware Discussion
    Last Post: 04-30-2003, 11:35 PM
