Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Carputer keeps FREEZING!!!
    Aug 2004
    Houston
    I recently installed my Carputer yesterday. Every once in a while it would just freeze and keep skipping the music on the last beat it was on. I am currently running FrodoPlayer. My setup consists of:
    old Compaq p3 1ghz
    192mb sdram
    dynamix 7" touchscreen
    itps and ps200
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    I hear "bugbite" telling you is the ITPS and the PW200 already...... by the way that is my config for power and no problems so far...
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Aug 2004
    Houston
    O yeah, sometimes a blue screen would pop up and say something about memory? Maybe I need more memory? but I am only running Frodoplayer and nothing else. Only Frodoplayer is running. could it also be that my HDD is old?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    sounds like the board is shorting on something (or bad ram....not a lack thereof)
    PC Components:
    My work log
    Nov 2004
    Well if you have that warning why don't you check the memory stick to see if is bad.
    Search for "memory testers" you will find some soft to run the test.
    It doesn't matter if you just running FP or windows or anything else if the module is bad is time to get a new one (the prices of memory are down BTW)
    Thanatos
    Nissan Aux-in MOD
    Aug 2004
    Houston
    Memory sticks are still good.
    Now my windows will not even boot up. Right when the Windows loading screen appears the blue error screen comes on saying:
    "A problem has been detected and windows has been shut down to prevent damge to your computer.
    UNMOUNTABLE_BOOT_VOLUME
    If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
    Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
    If problem coninues, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable components, restart your computer, press f8 to select Advanced Startup Options, and then select safe mode.
    Technical information:
    *** STOP: 0x000000ED (0x80EAFA60, 0xC0000032, 0x00000000, 0x00000000)"
    Someone help! im going crazy!
    Aug 2004
    Houston
    ---UPDATE---
    If this happens to anyone else, the boot file was corrupted and all you have to do is place the XP disc into the cd rom and repair the boot files.
    I think what caused this in the first place is the ITPS not properly shutting down the computer. How can I avoid this in the future??
    FLAC J187's Avatar
    Nov 2004
    Boston
    Quote Originally Posted by Luderboy
    ---UPDATE---
    Glad you fixed it. Just to give you a heads up, I have found that windows' fixboot can be a little quirky. For instance, windows comes back minus some system files that it needs for certain apps. A couple of times after fixing boot I had to do a fresh reinstall to get everything back. Well, actually I prolly could have fixed it, but I was too damn lazy.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Aug 2004
    Houston
    I just took my car for a spin today and it still keeps freezing. I don't know how to solve this one. Anyone have any ideas? The computer is in the trunk with a sub. Could that be it?
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    either you have bad memory, or a bad hard drive, or a bad motherboard... probably in this order...
    I would remove one memory stick, then another, if you have more than one, or try switching the slot it is on... I dont really trust mem testers since they can sometimes give you a fake OK...
    Then check with anohter HD, or try a scandisk and a defragmenting the hd... alternatively try re-formating (full format not quick!) the HD or another drive...
    if all that fails it might be a mobo to blame...
    Of course, before doing all of this, remove any peripherals, any usb devices, etc, leave it at a minimum since it might be freezing due to some peripheral being fuctup or bad driver or something
    Roy
    2005 Range Rover 4.4
  1. 99 Acura TL carputer project pics
    By Darkshear in forum Show off your project
    Last Post: 08-23-2007, 01:14 AM
  2. Replies: 6
    Last Post: 03-20-2007, 11:16 PM
  3. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
  4. My Weekend of carputer hell!
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 01-05-2005, 09:19 AM
  5. Replies: 4
    Last Post: 02-16-2004, 10:08 AM
