Results 1 to 8 of 8
Thread: power/battery question
    Jul 2005
    Hello. I have done a lot of searching and reading through these forums, and there is one thing i haven't found. (I am completely new to this btw). I've read how i can get a DC-DC power supply, or an inverter. If i went with a 150watt DV-DV power supply and ran it straight off the batter, what kind of drainage am i looking at from the battery? (like over a period of time). For Example: if i drove my car for 8 hours straight, and had the computer on the entire time, would it still be working? ...
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    If you're driving your car, the alternator is charging the battery, so it won't matter. The only thing that matters is when the car is off and the Alternator is not charging the battery, then the battery will die probably in a matter of minutes or maybe an hour, depending on the type of battery you have.
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    it would have to be a very small (or very old and nearly dead) battery to last less than an hour.
    Jul 2005
    ok. but as long as i start it up before it dies i should be fine. correct?
    Oct 2004
    Hertfordshire UK
    sure, thats what an alternator does, recharge the battery as well as feed the electronics in the car.
    anyway both the main 12 dc/dcs have line sensing where if your battery drops below about 11v (opus) for more than 10 seconds itll go into whatever shutdown mode you have programmed normally
    If you plan do do a lot of on-time without recharging perhaps look at a second one with a split charge or at least a deep cycle main battery- but for the occasional hour or two at a standstill your normal battery will be fine.
    In anycase, anyone that runs ice or a pc at a standstill should always carry jumpleads in the boot as a precaution.
    Jul 2005
    is the alternator powerful enough to recharge two batteries? could i hook another one up in my car just to be safe? (I have a '93 Honda Accord btw if it matters)
    May 2005
    Conyers, GA
    It probably would be, especially if you start with charged batteries. You'd probably want to get a deep-cycle battery as a second battery, so it doesn't get destroyed by constantly draining and recharging. Also, you'd probably want a battery isolator of some sort. (I think i've seen 'em at Pep Boys recently)
    Oct 2004
    Hertfordshire UK
    no point me repeating how to make a split charge circuit, instructions are easy to find with a search here, or even at your favourite ICE site
  1. Newbie question
    By jaydm in forum General Hardware Discussion
    Last Post: 10-21-2006, 11:07 AM
  2. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  3. Power/Battery question
    By wallyman424 in forum Power Supplies
    Last Post: 12-21-2004, 01:03 AM
  4. DVD drive question
    By Pokey in forum Newbie
    Last Post: 05-11-2004, 05:26 PM
  5. lcd power question
    By jrbless in forum LCD/Display
    Last Post: 04-07-2002, 01:27 PM
