1. no idea about the 3 pin - check the manual and drop Opus a email if you are still confused - and them post your fidning back here.
2. As for IDE - there a few threads on longer IDE cables so have a search and read through a few of the better looking ones. Thay are available or you can make them using some ribbon cable and some IDC connectors but you run the risk of getting errors. For occasional use and audio use they should be ok but if ytou are going very long then I would suggest using an IDE to firewire or USB2 adapter. (you need to convert the slim DVD to connector to regular IDE or 2.5" IDE and then get a converter to firewire or USB2).
I would go with firewire if you have it on your mobo as it is better as sustained transfer rates and youwill be using your USB for other stuff.
You could look for an external firewire slim CD/DVD case thatw ill have all the relevant adapters but remeber you will need a 5V supply to the drive form your opus.
Oh i just noitced you already ahve the slim to IDE adapter. In that case just get the IDE to firewire/USB2 adapter.
3. in work cant look too much
4. make sure you put the fuse on the +ve lead with about 18 inches of the battery to protect as much cable as possible. 15A should be plenty. You would have to be running at full load and less than 8V input to blow it.
LinkBack URL
About LinkBacks
