I believe so.
Joshua Jones - New Folk Singer Songwriter & Web Site Design (Yep, that's what it says)
Plans:
Micro ATX MB, 1.6 Ghz AMD AthlonXP-M, 512MB RAM, 20G 2.5" HD, Thinline DVD, 10" Touchscreen Display (Front)
Web Log
I believe so.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
are you using an inverter?
PC Components:
My work log
if so, ground the inverter, and use at least 12 gauge wire, i grounded an inverter once with 18 guage once, melted the plastic coating on the cable
PC Components:
My work log
no inverter right now. My system is on the bench still, and I am using a 120V PSU to test things out.
Plans:
Web Log
