Results 1 to 10 of 11
Thread: In theory (Electrical)
    Low Bitrate homchz's Avatar
    Jun 2005
    Lee, NH
    I had a very small fanless 500mhz board that ran only on 5v and a ground. Two wires, that is it.
    Now I have this AXT board with 20 wires and I wonder why all the mess.
    THe board takes 5v? Correct
    I have two 5v devices and a 12 volt fan. Nothing that I know of is 3.
    In theory can I power just the 5v and 12v lines and have everything work?
    Joshua Jones - New Folk Singer Songwriter & Web Site Design (Yep, that's what it says)
    Plans:
    Micro ATX MB, 1.6 Ghz AMD AthlonXP-M, 512MB RAM, 20G 2.5" HD, Thinline DVD, 10" Touchscreen Display (Front)
    Web Log
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by homchz
    How about you give more information about the new board. Also, did you search Google to see if you can figure out what voltages the MB needs.
    Michael
    Jun 2005
    Lee, NH
    I have tired to find the operating voltage on-line but have had no luck as of yet. Though my meter reads 4V at the power switch so I am thinking 5 is right.
    Board is a BIOSTAR M7V7IZ
    Plans:
    Web Log
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Are you sure that is the board number. I can't find ANYTHING about it.
    Michael
    Jun 2005
    Lee, NH
    My mistake
    M7VIZ one less 7
    Plans:
    Web Log
    FLAC alti's Avatar
    NY
    you want to hook only 5v and 12v up the atx on the motherboard???
    If that is what you are looking to do then no, it will not work. you also need 3.3v -5, and -12 as well as grounds connected to all of the ground connections on the motherboard and a atx power supply has one wire (i beleive the purple one, but you wuold have to look it up) that triggers the power suppply on and off.
    sorry if i misunderstood what you were asking.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    Jun 2005
    Lee, NH
    Nope no misundertanding. Thanks for the info. It is what I figured, just curious as to what the 3V is even for. I appear not to have any 3V accesories.
    Plans:
    Web Log
    FLAC alti's Avatar
    NY
    most logic circuits use it.
    only since the pentium iii did the processor pull form the 12v rail. and even though it does it still steps the voltage way down. (for instance the athlon 64 venice i have in my desktop is slightly over volted right now at about 1.53v)
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
    FLAC evandude's Avatar
    Mar 2005
    Maine
    3 volt accessories? you do realize that your MOTHERBOARD needs power as well, right? not just your accessories...
    plenty of things on the mobo run on 3.3v, and the -5v and -12v rails, although not used all that much, are still required by some parts of the mobo... (the -12v doesn't get used much anymore though)
    if you are really curious what rails you can eliminate, try unplugging those wires from the ATX connector. see if it can run without -12v... see if it can run without -5v... then unplug the 3.3v and watch it not run
    either way, you're going to end up with at least 3, probably 4 power rails you NEED to use, so a single ATX supply is the best way to go. that 5v motherboard you had probably had on-board DC-DC to generate other voltages as needed.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Or Better yet
    http://www.biostar-usa.com/mbdetails.asp?model=m7viz
    And I quote
    Hardware Monitor:
    CPU Fan Speed
    System Voltage
    CPU Temperature
    System Temperature (Optional)
    Vcore,+3.3V,+5V,+12V
    Why would it monitor something it does not need.
    Also, SDRAM uses 3.3 volts, and Believe DDR does as well. Since that baord only accepts SD or DDR ram, it must use 3.3 volts.
    Michael
  1. Replies: 2
    Last Post: 10-28-2004, 02:52 PM
  2. Replies: 6
    Last Post: 09-30-2004, 05:38 AM
  3. Theory on why Lilliput touchscreens die
    By archimense in forum LCD/Display
    Last Post: 08-27-2004, 02:12 AM
  4. Replies: 13
    Last Post: 12-12-2003, 02:26 PM
  5. any truth to the diagonal hd theory?
    By backpack09 in forum General Hardware Discussion
    Last Post: 08-07-2002, 09:15 AM
