Results 1 to 10 of 11
Thread: Quick pre-install questions
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    Doing my install tommorow, where should the distribution block be placed, under the hood?
    and where should the dssc go?
    How many people put the backs of their casing back on the lcd once it is mounted and bonded into the dash?
    2000 Sunfire build 100%, or is it ever really 100%?
    Constant Bitrate UnsanePyro's Avatar
    May 2005
    RI
    I put the back of my lilliput back on after I had it bondod into the dash, because when I took it apart, I left some stuff in there, so it was just easier to put back together like that.
    I'm still not really done, I just wanted it up and running so I could test it and whatnot, the finishing work will get done later.
    Good luck with the install.
    Apr 2005
    Queens, New York
    No this distrobution block should be close to where the power connector for the PC is. Are you putting the pc in the trunk? Then Distroblock goes to trunk. Just run 1 power cable from battery to trunk to distro block. Then feed all other power cables from the distro block to your other things that need power.
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Jun 2003
    Arkansas
    Quote Originally Posted by Cheekz185
    Ok, I understand that, I bought a fused distro block so I wouldnt have to put inline fuses, so I am going to have to anyways?
    Jun 2003
    Arkansas
    Ok, one more thing, the distro block has two 30 amp fuses in it, which is more than enough to support what i am running. I am going to try to put another inline fuse under the hood.
    Is there and drawbacks of using bigger fuses than needed?
    Raw Wave lostreception's Avatar
    NY
    bigger fuses yes smaller yes a fuse is like a bridge. electricity are people tryin to cross that bridge if your bridge holds 30 ppl max and on the other side of the bridge is a house (computer/amp whatever) and your house has a 20 person limit then 10 ppl are gonna be out side banging on your door trying to get in but they cant. some of them may get in, hey a few party crashers no big deal. now i got 21 but this line of ppl to get into your party goes a few street blocks down cuz your one popular mofo. so now theres 10 ppl trying to bust into your house (computer/amp)
    ultimatly your house gets damaged
    same problem happens if your bridge only carrys 10 ppl and you house can hold 20 because the opposite will happen not enough ppl will be coming by to make the party seem interesting and the party will be weak so you turn up the music then everyone across the bridge hears the sounds and run across the bridge and it comes crashing down (blown fuse)
    this has been an analytical story by lostreception
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Jun 2003
    Arkansas
    Quote Originally Posted by lostreception
    bigger fuses yes smaller yes a fuse is like a bridge. electricity are people tryin to cross that bridge if your bridge holds 30 ppl max and on the other side of the bridge is a house (computer/amp whatever) and your house has a 20 person limit then 10 ppl are gonna be out side banging on your door trying to get in but they cant. some of them may get in, hey a few party crashers no big deal. now i got 21 but this line of ppl to get into your party goes a few street blocks down cuz your one popular mofo. so these 10 ppl tring to bustinto the party and your house (computer/amp) gets damaged
    same problem hapens if your bridge only carrys 10 ppl and you house can hold 20 because the opposite will happen not enought ppl will be coming by to make the party seem interesting and the party will be weak so you turn up the music then everyone across the bridge hears the sounds and run across the bridge and it comes crashing down (blown fuse)
    LMFAO, great story, to get to the point, im fine with bigger fuses than what i need.
    Feb 2005
    Madison, WI USA
    Heh, actually, I think the point was that too small fuses arent good, and too big fuses arent good. You want a fuse that is just right for whatever you are protecting with the fuse.
    Jun 2003
    Arkansas
    Well, im going to try to run it with the 30 amp fuses
    I am running a 100 watt pioneer amp on one, and a 350 watt inverter on the other, so....
    Apr 2005
    Queens, New York
    Quote Originally Posted by CavityCr33p
    You better put an inline fuse under the hood!
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  1. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  2. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
  3. First Install questions
    By c4shm0ney in forum FrodoPlayer
    Last Post: 07-29-2004, 02:33 AM
  4. more quick newbie questions
    By Cliff in forum General Hardware Discussion
    Last Post: 04-03-2002, 11:21 AM
  5. A few quick questions anyone can answer...except me.
    By JackMode19 in forum General Hardware Discussion
    Last Post: 04-16-2001, 01:07 PM
