Results 1 to 10 of 18
Thread: Another noob takes a brave step into the light...
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    Hi all.
    I thought I'd introdiuce myself & say a little bit about the new project I will be embarking upon.
    I have a 2003 Saab 9-3, and I'm (like everyone else here) gonna add a little electronic oomph to it. Why? For the challange, and to add expandability to the car. There are a bunch of things I WANT to add, we'll see if they ever make it. I would like to make copious notes here since it seems I'm the first of my car to do this on this forum.
    Here are the goals:
    -Wireless Networking
    -Bluetooth
    -DVD drive (multireadable)
    -Touchscreen monitor that hides in the CD slot
    -Freakin huge HDD
    -GPS integration with Navigation
    -Ibus interconnectivity
    -XM integration for my existing Commander
    Seamless, stock appearing, and invisible.
    I have read enough on this forum to give my nerd-seasoned brain a run for it's money, so I'm not asking any questions...yet.
    My first challange: where to put it. I have a couple candidates in mind.
    -Under Passenger seat
    -Inside spare tire in trunk (must relocate tools currently occupying spot, and get past ventilation issues)
    -Inside rear seat armrest
    -Not stealth: just glue it to the back of the rear seats.
    I am also starting to look at components. I really like the Ikea box idea, cause it's a good fit for the mobo & power that I am interested in, but 1 but point for me is that I want a 3.5" HDD. Karbo+3.5" HDD= no go. So we'll see. In fact, the M10000+3.5" HDD is 1mm bigger than space allows in my spare tire, and that's without the case. So we'll have to get creative.
    The only thing I'm 90% certain I'm getting is the Xenarc 700IDT In Dash 7" Touch, as it will replace the CD player in my dash, and fit nicely (I think...gotta break out the tape measure).
    Check back later, and any comments welcome!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Welcome! You're doing your reading -that's great. Sounds like you're on the right track so far.
    ...If you only need 1mm in the spare tire space, well, there's got to be a creative way to make that fit. Maybe remote mount the HDD. Go with an external unit?
    Want to:
    Jul 2005
    Motor City
    Thanks Bugbyte, I appreciate the encouragement. I've seen many of your posts here!
    I think I found my perfect case.
    http://www.officedepot.com/products/...76/;:10gg9eb56
    The plan is to put the 3.5" & PU in the lid, and the MB in the base. I have to trim some stuff, and make all the other holes, but what a great find, and a great start! I don't need the lock, but eh, added bonus.
    Once I get all my components & put it in, I'll make a proper post in the Tech section. No one here has used this.
    Partilculars:
    Valutz Cash Box, $20
    Inner Dims: 230mm x 190mm x (60mm in base + 20mm in lid)
    Outer Dims: 253mm x 215mm x 95mm
    So by my feeble calcs that gives it what, a 1/2" armor?
    Next project, since I have a HD, is how to mount it. Where's that damn search button...
    Jun 2005
    Quote Originally Posted by Viscouse
    Wow, inside the spare tire......... won't that create a problem when you actually need to use the spare tire? It might be a little hard removing the carputer........ LOL
    Seriously though: Do you mean inside the spare tire well? If so, where is your spare tire going if any of the tires go flat or get screwed up going down the road?
    Jul 2005
    Motor City
    I mean inside the tire. I am not sacrificing my spare.
    My tire is concavely sitting horizontally in my trunk, under the floorboards.
    Nested inside there already is a toolkit.
    If I remove the toolkit, you can see the picture below. Access to the spare is not a problem, as I simply remove the puter. It will not be so rigidly mounted that I will have to unscrew it. I will use something else.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Under the passenger seat it the first place I will install the PC. Trunk is 2nd and spare tire is the last. Why? heat problem. Inside the cabin/under passenger seat, the PC share the AC with you. Other than that, you have to make some creative HOLES to cool the PC in the summer heat.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Jul 2005
    Motor City
    Thanks Matrix. That's the issue I've been grappling with. I'm still doing my research & searches, but here is what I'm coming up with so far:
    Seat: good airflow possibilities, but it gets really, really hot in the summer, and really cold in the winter.
    Tire: bad airflow (just move the heated air around in the well) but it will never get really hot. It will get pretty cold though.
    Since I can't fix the really really hot aspect of putting it in the cabin, but I can fix the airflow issue in the trunk, Trunk is up by 1.
    But...now that I'm thinking about it, the puter will not be running when the car isn't running, heat issue for the Seat is bearable. Seat is up by 1.
    I would love to put it under the seat, but there are some packaging concerns I have to work through.
    Newbie Paul H's Avatar
    Apr 2005
    Breda, The Netherlands
    The original mounting place for the Saab Amp/Navi-DVD player and CD-changer is in the left side of the trunk you can fit the computer there
    Paul
    (former Saab mechanical)
    Constant Bitrate JaymzRR's Avatar
    Jul 2005
    Issaquah, WA
    I don't know Saabs but have you looked at glovebox or armrest install options? Another option some I have seen you can remote install a lot of stuff, get as much as you can in the dash, mount everything else (and now hopefully substantially less stuff) under a seat or such. Of course with an in-dash fold-out style screen you probably have less room in the dash.
    James Radcliffe
    James@GoDivine.net
    Planning (Phase I)
    |||||++++++| 40% Making Final Pre-Purchase Plans
    Car Stereo (Phase II)
    |||||||||++| 80% - Building box, getting ready to wire
    Carputer (Phase III)
    ||+++++++++| 10% Desiging CarPC case
    Jul 2005
    Motor City
    Paul, thanks for the advice. I thought of that, but I would have to to cram it into the smallest form factor possible, and I wanted some flexibility to use some oddball parts, like a 3.5" drive.
    JaymzRR, thanks but i'm not a fan of spreading parts around (although I did think about it). There is VERY little room in my dash. What room is available is now taken up by the XM Commander box.
    I think the seat option wins. I also like the idea of easy access (fast removal), and the allure of not running cables all over the place.
    Thanks guys!
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
  1. Iguidance and Centrafuse Lowering volume?
    By fenderbender in forum GPS
    Last Post: 07-01-2008, 03:38 PM
  2. How many does it take
    By veedubya in forum Off Topic
    Last Post: 06-03-2005, 01:15 PM
  3. Gamma control by light sensor
    By kronos in forum General Hardware Discussion
    Last Post: 03-14-2005, 08:57 AM
  4. BU-303 Dim Light????
    By KingsDude in forum GPS
    Last Post: 02-12-2005, 10:23 PM
  5. How Many Does It Take...
    By mp3z24 in forum Off Topic
    Last Post: 09-19-2004, 11:54 PM
