Yes.
Hi there
Hooking up an amp to a carputer. problem is that the head unit which is SUPPOSED to be hooked to the amps is what tells the amps to turn on in the first place. any thoughts on how i can manually turn on the amps at any given time? maybe with say a switch of sorts?
Thanks for the help,
~N8r4d3
Yes.
Post Whore's tip:
User CP-> Edit Options-> Number of Posts to Show Per Page-> 100
http://www.frappr.com/mp3car from this thread http://www.mp3car.com/vbulletin/general-mp3car-discussion/65044-frappr.html
wire remote switch to ignition switch
badda bing
[||||||||||||||||||||] - final touches
SUPER 7" VGA w/ TS
Toshiba Satellite 3000
P3 850
256MB
30GB
Geforce2 Go
DVD
Orinoco 802.11b PCMCIA
nlite WinXP 350MB installed
RoadRunner
iGuidance 2.1
Holux GM210 GPS
Xantrex Xpower 300
the remote wire is just a low wattage 12v feed.....so any 12v source thats either switched, or switched by the ignition will work
PC Components:
My work log
