Results 1 to 10 of 16
Thread: M1-ATX Pictures of wiring....
    Apr 2005
    Has anyone done a DIY with real pictures on how to wire an M1-ATX. I am not good at reading wiring diagrams, I need pictures, so if anyone has set one up then it would be very helpful. My biggest thing is how the heck do you tap an ignition wire and how do you use a fuse box? Sorry don't know electronics at all.
    May 2005
    Chico, CA
    bump
    Jun 2004
    Central California
    Taking real pictures of wiring is not only tedious but also impractical. Every car and installer has different setup.
    In order to help you to answer the question, though; you're having problem taping to the ignition? Or, having problem finding the ignition?
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    the thing people have trouble with is the ACC or ignition line with the m1-atx. here is a pic of how to do it:
    This is on J-body car I found the pic like 4 minutes after reading your post. You pick a fuse that controls something that can only be turned on if your car is on. I used the windshield wipers. That is tapped into the fuse... the way that i did mine was to wrap the wire around one post of the fuse, then jam it into the fusepanel real tight.
    The other two line go straight to the battery, there should be a rubbery thing that you can put a hole through to send wire from the cabin to the engine. Also some people use the car chasis as a ground point. In a few days I will be posting picutres of a few more steps of my carputer and you will see what I am talking about
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
    Constant Bitrate techeros's Avatar
    Mississippi
    are you refering to this?
    http://www.t3tundra.nighttek.com/polk_install/MVC_754F
    03' Toyota Tundra T3 Special Edition - Polk Audio speakers - Sony 4ch amp - RF Sub amp
    Carputer Planning |---------*|
    Overall Implementation |---------*-|
    (Stereo complete)
    Computer installed and working
    Feb 2005
    S Ohio
    yeah, but on my car its bigger....
    My NEW carPC
    Mississippi
    oh you mus be taking about goin through the stearing column rubber boot
    (Stereo complete)
    Feb 2005
    S Ohio
    yarrrrgggg----- thats pirate for "yes"
    My NEW carPC
    Mississippi
    rrrrrrrr - thats pirate as well for "Running through the rubber boot is better than having to drill and buy rubber gromets."
    (Stereo complete)
    Jul 2005
    Brisbane, Qld, Australia
    No offence, but that fuse box method is rather dodgy. You'd be better off testing what wire behind the ignition switch has ACC power and then soldering a wire to that.
    Oh, and make sure you USE FUSES IN POWER WIRING.
  1. Combining two ATX cables
    By LockNTross in forum Power Supplies
    Last Post: 09-22-2006, 08:51 PM
  2. M1 ATX problems
    By Tompa B in forum Power Supplies
    Last Post: 09-25-2005, 07:39 AM
  3. Whats happens -> M1 ATX combined power overloaded?
    By Me&you in forum Power Supplies
    Last Post: 05-09-2005, 04:28 PM
  4. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
  5. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 03:22 PM
