Results 1 to 7 of 7
Thread: What can a stock IGN power cable handle?
    Jun 2005
    London, UK
    Heya,
    I've been looking over the thread here: FAQ: Connecting your Car PC's Power and Speakers
    And i still can't work out if the stock cable that provides the 12V when the ignition is turned will handle the current used by the opus PSU? If not i can't see anywhere where the cable gets thicker... at all =\.
    Could a possible solution be to use about 5cm of the stock wire from the harness and then switch it to 8AWG wire?
    Will i need to fuse the IGN cable anywhere like the power cable?
    Regards,
    Rob.
    Jun 2004
    Central California
    Rob, you could always use a relay. Have this relay triggered by the IGN and for the load side, have it powered directly from the battery.
    What are you trying to do, anyway?
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
    Jun 2005
    London, UK
    Well after using the search (:P) i found this Opus acc line wire guage, is 18 the smallest?... seems to answer my question as the IGN (acc) cable won't actually handle more than 5ma with the Opus.. sorted
    May 2005
    Derbyshire, UK
    The IGN line just tells the opus to power up/down. The power is supplied by a large guage wire directly from the battery..
    From the thread you linked to..
    You cannot draw your power from this connector because the wire is not thick enough for the amount of current you will have to draw, you will end up burning out the wire and possibly starting your car on fire. This is why you must run large cable 4-8 gauge from your battery.
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
    Jun 2005
    London, UK
    So am i right in saying that the stock wiring harness can cope with the small signal the opus needs to tell it to power on?
    May 2005
    Derbyshire, UK
    Quote Originally Posted by m00ie
    Yes it can....
    Old setup
    New setup
    Jun 2005
    London, UK
    Great thanks I'm slowly learning my way around all this stuff. I just like asking questions to double check things.
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 07:45 AM
  2. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 10:48 PM
  3. Power Question/Setup Question, minibook pc
    By seamonkey420 in forum Newbie
    Last Post: 05-17-2004, 09:47 PM
  4. Ribbon cable enough to power lcd?
    By pinkysqueaks in forum LCD/Display
    Last Post: 10-04-2001, 04:39 PM
  5. What gauge of cable for LCD power?
    By dudah85 in forum General Hardware Discussion
    Last Post: 05-24-2001, 10:18 PM
