Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Fuse for ACC
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    Fuse for ACC
    Im not a expert, or even a decent novice when it comes to car electronics. I am trying to figure out if my ACC crimp behind the lcd in the dash is loose, or if a fuse blew.
    How did I find the fuse, or what would be effected if the fuse blew?
    2000 Sunfire build 100%, or is it ever really 100%?
    Constant Bitrate stapan's Avatar
    May 2005
    SoCal
    in most cars the fuses are under the steering column all the way to the left and all the way back by the firewall. you may have to remove a panel or two (usually clip-on not screws for these). sometimes the fuse block is somewhere else, like in the trunk or under the hood. check your owners manual for the car which should also hopefully have a diagram of what fuse is what in the fuse box cause its usually hard to read the labels next to them.
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    The sunfire you have to open the door and its on the side of the dash if I remember , a little cover.
    Jun 2003
    Arkansas
    Ok, I found the pwr acc fuse and it looked fine.
    it was blue 15 amp fuse. This is the same control that turns the headunit on right? That is where I took the 12v switched from, the old HU harness.
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    You want to check the radio fuse, since you used that for the ACC power.
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
    Jun 2003
    Arkansas
    Any idea what that fuse would be labelled? Ive lost my manual somwhere and didnt see anything that stuck out as the radio fuse.
    Feb 2001
    The cover should have a picture of were each fuse is.
    ODYSSEY
    Digital-Car UK|
    (\__/)
    (")_(")
    Dec 1969
    Look behind the plastic panel.(that covers the fuse box)
    ODYSSEY Beat me to it
    Jun 2003
    Arkansas
    Yea, I knew that! heheh, I didnt see anything labelled radio or even rad....what would that fuse typically be called on the diagram?
    Dec 1969
    Post a pic?
    Also check under the hood for another fuse box(doubt a radio fuse would be there).
  1. Fuse popping, wire heating up!
    By gumbi4u in forum Power Supplies
    Last Post: 06-29-2006, 11:01 AM
  2. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 08:03 PM
  3. Lilliput Lcd fuse blown help!!!!
    By fernando11554 in forum LCD/Display
    Last Post: 05-16-2005, 12:54 PM
  4. Xenarc fuse and power help required
    By Scouse Monkey in forum LCD/Display
    Last Post: 02-18-2005, 03:45 PM
  5. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 05:59 PM
