Results 1 to 10 of 13
Thread: Winter problem!
    Aug 2005
    Winter problem!
    hey,..I'm living in Montreal, and we get some snow in the winter...I would like to know if anybody put a pc in a car with extrem temp ??
    and if yes what did you do about the condensation ?
    hey thanx
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Been asked before do a little
    Search tips
    extreme temps
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    May 2005
    Vienna, VA
    well, to save you some searching and reading, nobody has ever come up with a definitive way to prevent hard drive/system freezing in the winter.
    The best solution is to use a compact flash card for your OS.
    You need to find a hard drive that doesn't use fluid bearing for cooling. They either don't exist or are very expensive. However, some people seem to have no problem with their drives but it's pretty much a crapshoot. The same drive, same model number will freeze for some and not for others. Nobody knows.
    Even then, it's still not guaranteed that your system will start up properly.
    Aug 2005
    I come from the land of extreme overclocking so cold temps and computers are an area I have experience in.
    Condensation will probably not be an issue. You dont get frost inside your car do you?
    Most computer electronics really like colder temperatures. CPUs are quite happy running at 40 below 0.
    As stated before, hard drives might be a problem, but I think this too is easily remidied. Vapochills (computer chiller units) have a little warming pad they put under the cpu for condensation prevention that plugs into the power supply. I would imagine something like this could be adapted to keep your hard drive warm.
    Another simple solution would be aprewarming box for the hard drive. You could use a readily available car drink heater and have it prewarm the hard drive so it will boot nicely.
    Once the hard drive is running and up to operating speed, it should produce enough heat on its own to be just fine.
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Ham Lake, MN
    yeah .. the hard drive likes to stick at -20 or so .. I've had mine to -35 or so.. but once it spiins it's good to go..
    I'm thinking of using a solid state drive soon myself.. or jsut parking in the garage :-)
    Shawn
    Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by gter
    You didn't say if you have a pc or not, anyhow, if it's inside the passenger compartment, the easiest solution is to let the car/cabin warm up , then turn on the pc. You can also run a tube from the cars (floor) vents into the pc case. I did that, but mainly for cooling.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    is this another attemp for a zombie thread? moreover what kind of weirdo would like to chat about a winter problems in early August??
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by LagunaICE
    Jun 2005
    Michigan
    Someone who actually likes to plan ahead and be prepared?
    Oct 2004
    NY
    as stated, the only real problem is the hardrive... and maybe the lcd until that warms a little...
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. A little problem with my car... Maybe...
    By BoyNextDoor in forum Power Supplies
    Last Post: 11-13-2004, 09:58 PM
  3. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 02:38 PM
  4. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 12:09 PM
  5. Replies: 8
    Last Post: 12-31-2002, 12:37 PM
