Results 1 to 6 of 6
Thread: VGA not working...
    Apr 2005
    VGA not working...
    So I installed my carputer (finally) tonight and I turned it on but my lilliput says "no vga signal" so I take the mobo up to my room plug it in my tower and 15" lcd and i can see the bios fine. I take it back down to the car and nothing... any ideas?
    Anyone near Highlands Ranch that wants to have a look and help troubleshot?
    Aug 2005
    try plugging another computer i.e. laptop into the vga cable. if that doesn't work, try another vga cable. if that still doesn't fix it, then your screen is bad.
    99% chance the cable got disconnected or something stupid like that.
    Maximum Bitrate shizzle's Avatar
    Mar 2005
    Sarasota, FL
    yeah my lilli gave me that signal sometimes... it would get the signal just by bumping the cable's connection to the monitor.
    Carputer status: [-*---------]
    Im thinking laptop...
    Apr 2005
    Its plugged in fine I can see it, gonna take it up to this compy sometime later, I tested the setup when I got all the parts and it worked fine.
    Apr 2005
    OKay I think its actually my PSU
    http://www.mini-itx.com/store/?c=10#p1808
    Note: This unit is NOT compatible with any other kind of motherboard due to (amongst other things) physical and startup timing differences - suitable *only* for EPIA M and MII motherboards.
    Should've done my research... any way to have this thing work with my mATX mobo?
    --edit--
    My cpu fan comes on when I turn the compy on, but thats about it.
    Aug 2005
    Detroit
    What PSU are you using currently? I may be having the same problem, so i'm curious.
  1. Wireless VGA
    By Jimbo1978 in forum General Hardware Discussion
    Last Post: 03-01-2005, 08:32 PM
  2. Replies: 22
    Last Post: 01-05-2005, 01:47 PM
  3. Replies: 6
    Last Post: 12-21-2004, 03:47 PM
  4. Xenarc VGA or Composite
    By GTPmp3PC in forum LCD/Display
    Last Post: 01-14-2003, 11:15 AM
