Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: Powering External Harddrive
    Spring Hill, Florida
    I have a 250gb Seagate External HardDrive (3.5") in a USB2.0 enclosure and I was wondering how I would power it...my plan was to use the Opus 150, but is it as simple as cutting off the AC adaptor and wiring it into the Opus? Then my next question, does the Opus come with the necessary connectors to do this?
    2005 Black Chevy Impala
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by Shelbrain
    I'm no pro, so I forget the name of the connector shown below. This connector comes with the Opus. Just wire in your external HD to the opposite connector and plug it in. You can get them at places like CompUSA.
    Just be sure to get the polarity correct.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    It depends on the power supply for your USB drive, and what voltages it puts out. It should say on the bottom of the power supply what it puts out.
    It says:
    Input :100-240Vac,.6A,50/60hz
    Output: +5V 1.5A
    +12V 1.8A
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    No need to use the power part of the enclosure... just use the opus to provide power to the HD. (like having a regular HD but apart of the system)
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    It is not a bare drive...should I just cut into the enclosure?
    Nov 2004
    When you said enclosure you mean those plastic cases that you use to put a regular HD (comes with a short IDE cable and a male morex) right??
    Just mod the case with a female morex and use the opus to power it... (use the same hole that is for the power cable)
    Thanatos.
    Nissan Aux-in MOD
    Here is a link to what I purchased:
    http://www.gogocity.com/product_deta...CO07HDD0802USB
    Nov 2004
    Same one..... just forget about the power part of it and mod a female morex using one of the existing holes.
    Nissan Aux-in MOD
    Ok thanks!
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. USB harddrive disappeared
    By blak3r in forum General MP3Car Discussion
    Last Post: 04-19-2005, 04:56 AM
  3. Replies: 5
    Last Post: 01-24-2005, 02:47 PM
  4. Replies: 10
    Last Post: 12-20-2004, 01:15 PM
  5. Booting From and external harddrive
    By Custom_L in forum General Hardware Discussion
    Last Post: 05-12-2004, 02:24 AM
