just browse the forums mate! all the answers are here!
The power of your battery is enough!
I use a couple of fuses.
1 80A near my battery.
My 2 amps have 30A each
My pc (opus 200w) has 20A
With out getting into like major break down of the products (brands or anything) this is what I am thinking. And here is the break down:
From Car Battery
1 x 0 Gauge wire to a distribution block (Fuse? What size?)
3 x 4-6 Gauge wire to CPU, AMP, SUB AMP (30W Fuse on each?)
From CPU
- Power comes in from 4-6 Gauge wire to a OPUS 150 watt power supply (do you use a molex connector?)
- Cords (VGA, and power to VGA) run to screen in dash… is this the best way to power my screen?
- 2x RCA cables to AMP’S
From AMP (how do I connect the on off wire that normal goes to the antenna?)
- Speaker wire to 10 speakers
From SUB AMP (how do I connect the on off wire that normal goes to the antenna?)
- Wire runs to 1 – 2 Subs
Other questions:
Will this be to much for my car battery?
Should I be running my power all the way back up to my VGA
Well thanks for all the help! I am sure I will think of more questions soon. And sorry if I am a post whore.
Cool thanks, how about the on/off cords from the AMP's ?
Right size for the wire running to my CPU (is it to big?, and how do you connect it in?)
does the system look about right?
Is the M1-ATX 90 Watt going to be better for what I want to do?
Thanks again!
I'm sorry but what is an Opus 200w?Originally Posted by TheKingPlaza
As far as I have known, and their site tells me there has only been 3 models 90w (depracted), 120w and 150w....
Roy
2005 Range Rover 4.4
I dont see why an m1-atx 90 is going to be better than an opus150!
Roy
my bad you are right 150.... and thanks again for the help... GREAT FORUM![]()
What size to the power supple for the computer? I want to buy my wires today.
Sweet... what did you run from the battery back (0G?) and what did you run to the AMPS and PC?
Any good?
http://cgi.ebay.ca/EFX-1-0-GA-4-way-...QQcmdZViewItem
-or-
http://cgi.ebay.ca/BRAND-NEW-BOSS-AU...QQcmdZViewItem
well now this really shows me how do things:
FAQ: How to Wire an OPUS PSU
