Results 1 to 5 of 5
Thread: Very new, few questions
    Aug 2005
    I am new to this, however, not to building things or electronics. Few questions before I start. My car is a 2005 Suzuki Aerio.
    1) Power. I see you need a certain type of PSU and inverters but where do you put the plugs and such? Do you need to take apart the dash? Will warrenties of any kind be voided?
    2) What is a good monitor to use from the 6-9 inch range, not from ebay.
    3) Where can I buy power buttons to put on the motherboard?
    Spring Hill, Florida
    1. For Power, the best is an Opus. Other people use Carnetix, M1-ATX, and then there is the good old fashioned inverter which also works well for some people. As for the plugs, you will use molex connectors to run wiring from the power supply to the motherboard, dvd drive, etc. The Opus and other similar power supplies should be connected directly to the battery
    2. The two most popular monitors are Xenarc and Lilliput
    3. You will not need power buttons if the use an Opus or somthing similar. They automatically startup and shut down with the car...
    Good luck...check out the FAQ section and search for the terms I have used for more details.
    2005 Black Chevy Impala
    Aug 2005
    How will I be able to connect it to the battery?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You will open your dash. You will most likely void any warranties on equipment you have. Welcome to car computing!
    First, read some of the threads in the FAQ section, like "How to wire your Opus" or "Typical car wiring diagram".
    Want to:
    FLAC -zip-'s Avatar
    Ontario/Canada
    Run a wire from battery to the Opus or whatever you decide. Make sure you reseach the gauge of wire needed and put a fuse close to the battery.
    Sound Stage
    Eclipse|MTX|Infinity
  1. questions and more questions
    By cortinaking in forum Newbie
    Last Post: 06-16-2005, 03:02 PM
  2. Box and In-Dash setup questions
    By Pale Rider in forum Fabrication
    Last Post: 06-11-2005, 03:40 PM
  3. Replies: 6
    Last Post: 05-25-2005, 12:53 PM
  4. Additional questions about LCDs: Is 400 nit too bright?
    By khiser0001 in forum LCD/Display
    Last Post: 05-06-2003, 08:13 PM
  5. starting project soon, questions..
    By tekknikal in forum General Hardware Discussion
    Last Post: 05-28-2002, 07:47 PM
