Results 1 to 3 of 3
Thread: Linitx 8" lcd panel size ?
    May 2005
    Belgium
    Hello, i try to find the lcd panel size of Linitx 8" inch screen. Made a lot of search already with but only find the complete unit dimensions.
    Any other 8" unit with a 4:3 ratio would give me an indication. I know that in the xenarc faq they are pictures of their 8" inch unit but the quality is not really good.
    8" Linitx
    May 2005
    Belgium
    Panel is 186mm x 141 mm
    Visible screen is 166mm x 125mm
    Switches are on small pcb 140mm x 20 mm
    main pcb 115mm x 85 mm
    usb controller 70mm x 20 mm
    received from Linitx.coml
    Variable Bitrate quantum's Avatar
    Sep 2005
    Is there info like this for the 7", and can it be taken apart like the Liliput so the LCD and controller are separate and outside the case?
    I didn't see any diagrams on this monitor when I did a search...
    Thanks!
  1. FS: NEC 12.1" LCD PANEL & CONTROLLER
    By Motorcity in forum Classified Archive
    Last Post: 04-30-2004, 09:09 AM
  2. FS: 3.5" SBC with 10.4" NEC LCD panel
    Last Post: 04-16-2003, 12:20 AM
  3. FS: NEC 12.1" tft lcd panel (12volt) w/vga controller, osd, etc.
    Last Post: 04-15-2003, 06:46 PM
  4. Sharp 10.4" Touchscreen LCD panel
    By Cameron in forum General Hardware Discussion
    Last Post: 08-20-2000, 05:19 AM
  5. Sharp LCD panel controller
    By slipstream8 in forum General Hardware Discussion
    Last Post: 04-17-2000, 07:48 PM
