Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Power IGN question
  1. #11
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    Nice thread.. learned some things because I need to wire my Opus very soon and I'm freaking out about the whole IGN wire thing.. I have no idea what and where to wire it... If I ready correctly, can I just wire it to the sig lighter and fuse it?
    -Emo
  2. #12
    Variable Bitrate 0okami's Avatar
    Feb 2006
    USA
    Quote Originally Posted by Emo
    -Emo
    thats what i understood too. correct us if we are wrong.
    ~0okami.Digital
  3. #13
    Jan 2006
    Illinois
    As long as the cig lighter shuts off when the ign is off -- Some cars have a constant cig lighter
    Jim
    2005 Acura TL
    2005 Honda VTX1800N
    PreludePC 2.0 in the making...
    Smaller, faster, better...
  4. #14
    Constant Bitrate stapan's Avatar
    May 2005
    SoCal
    Quote Originally Posted by 0okami
    so in short, if its a positive/hot/+ wire, always fuse it near the source. correct?
    yeah, that's right. spuzzdogg hit the nail on the head as far as fusing it as close to the battery/source as possible, or at least closer than the closest sheet metal.
    think of it this way... the wire is like a pipe that always carries water from a source (the battery, or your "cig lighter" wire). the fuse is like a valve on the pipe that when closed, stops water from going through at that point. so lets say the valve is on the pipe a mile after it leaves the source. if the pipe gets a hole in it anywhere in that first mile before the valve, water goes everywhere and you can't shut it off! (sparks, wire possibly catches on fire) closing the valve wouldn't do anything because its after the leak. however, if the valve is right near the source, you can shut it off thereby stopping the leak since the leak is further down the pipe.. the fuse just happens to be a valve that automatically closes if it detects a leak further down.. hope that amkes sense
  5. #15
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    Quote Originally Posted by stapan
    yeah that was a good example.. thanks
    -Emo
  6. #16
    Nov 2005
    Excellent analogy. Says it so much clearer.
    And the value (fuse) also prevents the water (charge) from draining away until your water source is empty (battery flat and dead).
  1. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  2. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 01:08 AM
  3. The Newbie with another power question
    By nixneon in forum Newbie
    Last Post: 03-21-2005, 12:05 PM
  4. Noob question about power supplies
    By Jagojon3 in forum Newbie
    Last Post: 03-09-2005, 12:35 AM
  5. Question about power and inverters and all that
    By SBmp3 in forum General Hardware Discussion
    Last Post: 05-01-2003, 12:35 AM
