Results 1 to 10 of 16
Thread: Power IGN question
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    Question Power IGN question
    I understand perfectly how to wire up an Opus with the Constant power. Search helped with that. What I could not find was different loads for the ignition wire.
    Opus needs Constant & Ignition power sources.
    Here's my question.
    I have an ignition switched cigarette lighter (which is not used for anything other than power). I already have an XM Commander (needs ignition as well) hooked into it. Can I wire an Opus 120W in there as well? Is the Igntion wire actually used or is it a "sense" wire to let the Opus know the vehicle is turned on & to go ahead & turn on/off.
    Thanks...
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    its a "sense" wire so that the Opus knows when you turn your car on and off again
    so unless your cigarette lighter loses power when you turn the car off... you cant wire it there
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    I mailed Opus and they said there is practically no draw, it is only used for switching. I have mine sharing a connection to my screen, FM modulator and radar detector all through a 7.5A fuse and no problems.
    Jul 2005
    Motor City
    Thank you kindly, that was exactly what I needed to know.
    Constant Bitrate CornToeGoblin's Avatar
    Dec 2004
    Texas
    Quote Originally Posted by Viscouse
    you could always put in a fuse if you paranoid
    2008 Civic... Sound system... then carputer install...
    WORK IN PROGRESS
    If you look at my avatar closely, you can see a chick with two big knockers....
    Variable Bitrate 0okami's Avatar
    Feb 2006
    USA
    Quote Originally Posted by CornToeGoblin
    what size fuse? sorry had to ask.
    ~0okami.Digital
    Constant Bitrate stapan's Avatar
    May 2005
    SoCal
    you should absolutely put a fuse if the wire is thinner than the wire you are tapping into. while the opus itself may not draw a lot of power on this line, the purpose of the fuse is to protect the wire itself in case something bad happens and the wire shorts out. remember, this wire is still connected to a hot source of power, and if the wire gets in contact with anything grounded -- whether its twisted sheet metal in a car accident, or just getting disconnected due to shock or vibration and the disconnected end touching something grounded -- you're looking at a serious fire risk without a properly rated fuse. the best would be to use the same wire thickness (so its properly protected by the factory "cig lighter fuse") or if needed use a lower rated cig lighter fuse than factory
    Feb 2006
    USA
    Quote Originally Posted by stapan
    so in short, if its a positive/hot/+ wire, always fuse it near the source. correct?
    *takes note*
    ~0okami.Digital
    Nov 2005
    Quote Originally Posted by 0okami
    *takes note*
    The fuse is actually to protect the battery.
    The idea of fusing as near the battery as possible is that in the event of a short-to-GND, the battery would not continue to drain with a large current until it dies (or until something catches fire from a spark or overheat).
    By fusing close to the battery, you also reduce the length of "hot" wire that may melt or spark or otherwise be vulnerable.
    Jul 2005
    Quote Originally Posted by piabu
    I don't know how you worked this out. It's standard practice to fuse electronic items - The first thing a textbook will tell you is that fuses ONLY save electronic components - not people. I guess a battery prob counts as an electronic component but i wouldn't say "the fuse is actually to protect the battery"
    My understanding of why the higher power cables are fused close to the battery is to reduce the length of positive cable protuding from the battery in the event the fuse holder came apart. The ideal length therefore would be to place the fuse at a distance less than the closest metal surface to the battery. I think this may be what you were trying to say - but I couldn't really make sense of your comment
    Spuzzdawg
  1. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  2. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 01:08 AM
  3. The Newbie with another power question
    By nixneon in forum Newbie
    Last Post: 03-21-2005, 12:05 PM
  4. Noob question about power supplies
    By Jagojon3 in forum Newbie
    Last Post: 03-09-2005, 12:35 AM
  5. Question about power and inverters and all that
    By SBmp3 in forum General Hardware Discussion
    Last Post: 05-01-2003, 12:35 AM
