Need to save your money for repairs on your Ford?(couldn't resist...)
Why go cheap? Seems to me if you use good quality components to begin with you will be happier with your system and better off in the long run. I decided that I wanted a Xenarc monitor because all I read on the Lilliput were people having problems with them. So I bought a brand new Xenarc that I found at the price of the Lilliput. Moral of the story is don't buy cheap things, just search till your fingers are bloody and sore until you find the best deal possible on good things.
The power supply question is hard to say. You need to figure out how many devices you will be running off it. GPS, WiFi, monitor power, XM, USB hubs, CD/DVD drives, etc.
As for your reciever, research the model number and see if it has an aux in. If you don't see a button up front that says AUX on it or its not satellite ready, then it probably doesn't. If its your stock deck on a 95 Stang then I'm sure it doesn't.
So, if you take the headunit out then you need an amp, and probably new speakers. The sound wires from the PC->Amp->Speakers. Easy and been done a million times.
Good luck with your project. Hope something here helps.
LinkBack URL
About LinkBacks
)... I've got the majority of the kinks worked out as I am an avid HTPC-builder and rather compotent at Car and PC repair (two favorite hobbies, as most of the people here, I would imagine.)
