Everything looks good...I have one query though. The dlyon rom the Carnetix is only a small current signal, I'm not familiar with the touchscreen wiring in your setup...is that all the IGN wire is, or is it gonna draw a decent amount of power through it ??
As for grounds, they are all good as they are. You can connect the Carnetix to the chassis instead though if it saves you running a cable front to rear on the car.
As I said, I'm not famliar with the wiring on that screen so can't advise on that point..
Fuses, you need a fuse in the live to the Carnetix (can't remember the rating but it's in the manual). Same goes for the amp.
The Carnetix outputs are regulated so no need for fuses really as it's internally fused in case of a short I think.
LinkBack URL
About LinkBacks
